Home > Help Needed / General Tech Chat > Knackered my sump plug thread :(
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Damn! think ive changed my oil once too many times now, that will teach me, the thread has knackered! Didnt try over tighten it, i think its just worn out basically, and wont even screw in tight without the copper washer :(
What can i do? I think ill just bodge it permanently this time with some hard oil resistant sealer and next time i need to change the oil ill just change the gearbox. thats all i can think of
you need to helicoil the sump plug thread,
They do wear out for sure - Having a copper washer, which isn't that much softer than Alooominum, and a large 'head' to the bolt is asking for trouble eventually.
As JimStar says, helicoil is the best way. It at least means it'll be a steel/steel contact on the threads, so won't wear out again.
Hard luck Feebs - it's just one of those things that happens to everyone eventually.
yeah helicoil is the way to go, not that difficult to do at all really. somewhere local would probably do it for ?20ish tops.
We also helicoil all our "hot" stuff so that they dont seize in. I did my turbo exhaust down pipe ones. Much better quality thread you get than just tapping cast
I've got an M16 tap in the garage if that is big enough to get a thread into what is left? Needs a 14mm base hole to form a thread.............
Helicoil without a doubt the best way to repair it, but the kits are expensive and you'd need a big size for the sump plug.
Star Mag
Member #: 375
Leicestershire
I Had this problem and as a quick fix managed to get it to stay in with that liquid metal alraldite stuff i know its a bodge but got me goin till i could do it properly.
maybe, but its cheaper than getting the gearbox rebuilt into a new casting
Yes, but tapping it out to a larger size cures it in situ without the expense doesn't it?
true, i didnt get what you meant the first time i read it!!doh
