Home > General Chat > Aaand another head gasket failure... Water damage!
Asphalt
Member #: 1027
Germini, black forrest
Don't know why, but there was only a very slight drop in top-end power notable...
What made me wonder were rusty and green spark plugs...
*surprised*
And, as thought but not hoped; disaster...
Late march, when I put the car back on the road, I noticed that over winter a bit of water had vanished in the rad. That was probably that. Cylinder 2, 3 & 4 have water damage, 2 & 3 are down to 7 & 8 bar compression, with a new gasket. So I suspect the rings have had it, as it also burns quite a bit of oil...
And this can't be a dodgy gasket - it's a NOS gasket from 1985! *hehe!*
Edited by Asphalt on 9th Jul, 2011.
[X] nail here for new monitor
Oh dear ........ *frown* those bores look very tierd ........... *Idea* time for a rebore new pistons etc..... there
usually 2&3 blown between is detonation cause................... but you want to be using a decent torque wrench most gaskets fail because most peeps use their grandads torquewrench........it was ok when he was a lad .....lol *hehe!*
sort the detonation and the torque figures
keep us posted *smiley*
Asphalt
Member #: 1027
Detonation could be a cause - I think that could be possible, as I indeed had - occasinally - problems with that. In low rev-high load situations. The engine made a 'pinging' noise (not unlike the noise when you would hit a manifold with a wire brush, a light, high 'pink'). Is this detonation?
Serves me right for not sorting that out in time, I guess... :(
I have another low-milage spare engine waiting for installation,as soon as I have the time to do that...
It's a n/a engine, btw. :) (1275, ~10:1 CR, MG cam, Inno large valve head, HIF6, ported manifold, LCB/RC40)
Torquing down the head; do you re-torque the gasket? Latest approach I heared was to torque it down as per manual, and tighten the nuts another 20° after one full heat cycle (adjusters out & all studs oiled). Without losening them first!
Jan
well in my book torque to 55ft pounds cold and leave it at that
RULE:- ... IF YOU HEAR A "PING" ...LIFT YOUR FOOT THE ENGINES LIFE IS THREATEND
keep us posted
NickG
Member #: 7912
Australia oi oi oi!
What about if it has been torqued down cold already? Just go back over it to check it's 55ft ?
pot_dan
Member #: 326
bradford, west yorks
Jan, maybe consider getting a head modified to lower the cr and run the turbo on this N/A engine? I have done this for years with no problems and a Benross head *smiley*
http://turbominis.co.uk/car/105/
