Home > Wanted > BMW K 16Valve TURBO KIT
Orlando
Member #: 3114
Buckinghamshire
I'm looking for a turbo kit for the bmw k 16V head, turbo manifold / down pipe / inlet manifold / throttle body / turbo, anything and everything complete engine set up
Please let me know what is out there
Unfortunately for you its a case of make it yourself as no turbo kit yet exists.
The other optioin is to contact specialist components as they are now doing a supercharger conversion if that tickles your fancy.
Always a shot try matty, he may make a custom manifold for you
MadMatt from the ausmini forum does turbo kits, exchane rate and shipping from aus might be a killer though.
as far as I'm aware there are no off the shelf kits which contain everything you need to do the conversion, however I'm sure if you contacted Specialist Components or Force Racing and offered them enough cash they'd happilly put a kit together for you, just don't expect it to be cheap.
Orlando
Member #: 3114
Buckinghamshire
Thanks for the info it looks like i might look at going in a different direction for know and just keep the16valve bits for a later project, i have a stroked crank and "S" rods anyone know of the availability of 73.5 pistons suitable to make 1430cc engine
hazpalmer
Member #: 9038
Carlisle, Cumbria
for the likes of pistons try MED
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
The compleet turbo kit is made for a K head.
http://www.rbracing-rsr.com/bmwturbos.htm
only it´s for a 2 wheeler *smiley*
If i have more toys than you when i die, I WIN
Speak to mr austin he may be able to help.
The manifold does tend to be a personal choice since some want the turbo in the same position as the 5 porter, and some like to have it up top where the carb used to be, there is also the choice of turbo to consider. Nothing is impossible for Fast Carl , you just need to know where you want the turbo and which turbo you want.
MadMatt
Member #: 105
Brisbane ,Australia
but yes the exchange rate is far better the other way around, the way it`s going i could almost grab a whole Hyabusa engine from you guys & swap for the turbo exh manifold *smiley*
www.miniman.com.au
