Home > Help Needed / General Tech Chat > shmoking analysis
hi chaps .
well heres the thing , racing my car , i erronously ignored the det light to a bit of a degree :$ and had it blow a hose off next run .no smoke at all,
put hose on ,then on tickover it started to smoke after about a minute of running . if i revved it the smoke would billow, then dissappear and it would be clear whilst revving ,.then tickover for a while and smoke again .
it then went onto 2 and i drove home .
head gasket was eaten through for about an inch betwen 2 ,and 3,. pistons look perfect . filled bores with oil ,not moved ,but maybe just too thick to drain down .
now the q is , is there anything about a blownhead gasket in that position ,that would make smoke ?
oh ,no smoke on the way home .and after it went onto 2 it never smoked again .
im tending towards a total strip and no 3 piston is cracked ring lands . but i thought its worth putting a gasket in and seeing if it still smokes .
pistons are omega casts .
smoke was bluish grey
no rise in water temp on way home .
regards
Edited by robert on 14th Jul, 2011.
evolotion
Member #: 83
Glasgow, Scotland
cracked ring lands? will smoke but wont drop oil in the bore?
Denis O'Brien.
only thing i can think apart from shagged lands is it was sucking oil from the push rod holes,
sorry denis ,was that a question ?lol
yes joe i wondered that , it was v oily on that half of the gasket , but the fire rings were shiny silver ...
along the same lines...maybe more likly is it pressureised the crankcase via the pushrod holes.
I guess all you can do is whack a gasket on and hope :/
evolotion
Member #: 83
Glasgow, Scotland
yeah sorry lol i skim read your post and didnt notice you had already suggested the ringlands :(
p.s. missed boring you with my drunken waffle this year haha!
Edited by evolotion on 11th Jul, 2011.
Denis O'Brien.
hmmm ,well the oil waa bit further down in no3 .
but a leak down test gave 8%9.%8.%11% hmmmm
Give it a try for the sake of a gasket Roberto!
Robert when my ring lands packed up, i could just see some damage if i looked down the edge of the piston. Stick the gasket on and try a comp test.
Mike
Edited by MikeRace on 12th Jul, 2011.
Have you cleaned the block between 2 & 3?
errr , moight have done ..
Thought you'd have it running by now...
oh god just read this whole fiasco...
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=295818
maybe this is connected with my local supplier can't get bk450 .so i have to wait another day for a full payen head set ..and,then it'll have 'made in belgium on it "!
there isnt a gasket meterial in the world what will stand detonation
i think you may be lucky robert new gsasket on and see ................ but if you have the time go for pulling the pistons and check................ i am not holding my heart out for them
hmmm may be ok.....
Well certinally no smoke. But Suzy said it sounds like a canal boat at tickover, hahaha!
bennyy
Member #: 9037
Doncaster, yorkshire
looks good to me, glad its ok robert. *Clapping*
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Sounded a bit v8 to me
Lucky boy! Back in fighting form order for MITP? *happy*
Star Mag
Member #: 375
Leicestershire
Excellent news!
should have given me a ring Robert i have a few NOS rover bk450's
yes lucky to say the least :)
nice legs
top man pleased for you :) looks like that was all it was :) we don't mind that.
