Home > General Chat > URGENT HELP NEEDED
andyuk1275
Member #: 9276
Darlington north east
Hi everyone, my mechanic mate has been assembling my engine tonight, what a chew.
He's try to put the pistons in tonight and the arp bolts I bought are too big in diameter, should we just put the std bolts back in or are the arp bolts a must...? If so is it ok to drill the rods....
Thanks
Get the right ARPs
DO NOT drill the rods.
whats the part no on the ARP packet?
as Tom says, dont drill the rods, they yould need to be reamed, and even then the bearing bore yould need to be re honed,
andyuk1275
Member #: 9276
What about the std ones, are they shat ?
MarkGTT
Member #: 1194
Shropshire.
depends what the spec of the engine is and what kind of power you will be aiming for.
andyuk1275
Member #: 9276
About 140 brake 10 psi max! But around 5 at first... Omega 10cc dished cast pistons
wintersurferuk
Member #: 2208
it seems a shame that you cant use the arp's, if your in a rush (mini in the park) you might get away with the old ones i dont know... but when you start driving, you will get the taste for boost, and its nice to know you got the good stuff! i hate my head bolts after snapping one, when i can its arp's
as joe is indicating, cheak there the right ones. good luck!
danrock101
Member #: 9277
Nottingham
power wont really make a differnce, it's the revs you need to worry about which you should be fine, it's not a high revving n/a engine with a 286+ cam...
bennyy
Member #: 9037
Doncaster, yorkshire
You should be ok with 140bhp, but like said above, how long is 10psi going to last, my guess is a month tops before you decide to try 12...15...18 lbs *wink*
I would say use the arp's while you can, just for peace of mind tbh.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
There really is no need for ARPs on an engine that will only see 7k maximum.
Low revving turbo engines have no requirement for uprated rods. The maximum stress on the rods (TDC on the exhaust stroke), is pretty much unnaffected by power made from a turbo engine.
andyuk1275
Member #: 9276
These are the pics ive got.
apparently theres 3 types of arp bolts...
Rods are out of an A+ engine.
Any help is appreciated
they are for cooper S rods,
you want the 206-6002's
andyuk1275
Member #: 9276
cheers for a fast reply joe mate. i can now get it sorted.
thanks pal.
no problem :)
