Home > A-Series EFI / Injection > Injector Dead Time
Interesting video about testing injector dead time:
http://youtu.be/lJgi8l-2XG4
There is also a thread in the MS Forum about this:
http://www.msextra.com/forums/viewtopic.php?f=131&t=41357
This is important to anyone using the siamese options on the MS2 or the MS3 as it is inevitable that you will be running low pulse widths at idle.
Edited by Paul S on 18th Jul, 2011.
jbelanger
Member #: 831
Montreal, Canada
It is more important for those using the siamese options but it's a good thing to have an accurate dead time value no matter what you use.
And making the measurements yourself with the hardware you're using will yield much better results than using numbers from an unknown setup.
Jean
http://www.jbperf.com/
Turbo Dave did this quite some time ago.
