Home > Help Needed / General Tech Chat > Dump valve hole.
Alex1340
Member #: 111
Loughborough
Hi, i have bought at last a mini turbo. currently the engine is standerd from a metro turbo, afew little additions like a intercooler, but its running standerd boost and has no dump valve..... i crave that little woosh soo... whats the best way of pluming it in to the plenim chanber? i can't do alloy welding and i don't know any one with the gear is it best to find a local compainy who would do it or does any one make them? or is there another way?
thanks Alex.
pot_dan
Member #: 326
bradford, west yorks
avon bar sell them, but tbh i thnk there expensive, a local company could p[osibly do it cheep (metty turbo knows someone that he got to do mine for ?30) or you could buy a fitting kit and just plumb it into your intercooling hose somewere? not as effective as the plenum but it will still work lol
HTH, Dan
http://turbominis.co.uk/car/105/
easy to do yourself then have welded, shouldnt cost much. prep is the hardest bit (well most expensive! lol!) so do that bit yourself.
here's a pic of mine
sorry about the size of the pic but you need detail *smiley*
AllanMcD
Member #: 414
Dalbeattie Scotland
Iain has your car been on fire ? *wink*
http://www.rabdunn.co.uk/
Nope *smiley* Not while owned by me.
well, occasionally after some welding, its alex's car now *happy*
My lastest has been on fire a lot today, new inner sills, door steps and a few more bits have been done today. *happy*
T3Tone
Member #: 252
Sunny suffolk
I found the end of a water pump or thermostate ideal for the mounting piece (was gonna put flange but thought it might spark off pervy comments) They are alloy and have the flared end:>
-MINI CLUBMAN 1380 TURBO-
Alex1340
Member #: 111
Loughborough
Thanks All. just 1 more question. what type of dump valve do i need??? i was going to just get one from ebay.
T3Tone
Member #: 252
Sunny suffolk
Diaphram type is probably best, the piston type ones (like mine) stick after a while because the seals react with the fuel and swell a bit. I managed to replace my seal with one made from viton which does'nt react with fuel. Cost ?6 mind for a farty little rubber seal but works.
pot_dan
Member #: 326
still find your spark plug amusing iain*happy*
T3Tone, do you have contact details to get that seal? i have a diaphragm D/V atm but wanting to get a baileys piston one sometime and will want to replace the seals.
cheers, Dan
top tip, can you give some details of the seals you used as mine is starting to stick
speedyminidave
Member #: 316
Staffs
i have a bailey dump valve had it fitted for a year now and no problems pretty loud.
AV-R Technologies
Member #: 345
Guildford Surrey
We now do a threaded dump valve. So all you have to do is drill and tap the plenum.
Or we can do if for you *wink*
http://www.avonbar.com
Alex1340
Member #: 111
Loughborough
how much would that cost? the problem is i have to take it apart to fit it, and at the moment this turbo is my backup car which im useing. so its going to have to wait till my 1380 comes back from the body shop.
T3Tone
Member #: 252
Sunny suffolk
pot_dan..
I got the seal from a company called bsl brammer, try www.bslbrammer.co.uk I had problems giving them a part number off there site!!! but what you need is a quad ring with a 33.045mm ID and a cross section of 1.778mm.
http://genius.bsl.co.uk/paramsearch.cgi
try this link to get part number.
Carl
Member #: 95
liverpool-on-sea
treaded dumpvalve now i like the idea of that dont need one but good idea*smiley*
icklebits
Member #: 228
threaded dumplvalve, thats whats going on mine, as soon as i get round to sending my plenum in to avonbar that is!
ryan
pot_dan
Member #: 326
cheers T3tone will give them a try think i have just got a baileys one off feeble.
i do like that idea Mr. Avonbar tho again i dont need one now as my plenum has been welded lol.
will be ringing you soon to order a lot of stuff lol
cheers, Dan
cheekym0nkey
Member #: 180
Northants
Could you not just drill and tap the plenum to take a male bsp fitting? These are avalible in loads of sizes!
yeah bet its just inch bsp. easy enough especially in alloy
cheekym0nkey
Member #: 180
Northants
Don't forget you can get bsp fittings in stainless,alloy & anodised
Edited by cheekym0nkey on 6th Apr, 2005.
Alex1340
Member #: 111
Loughborough
sorry to be stupied but BSP?? and its going to be abit tricky to drill and 1inch hole and tap it, wish i had that kinda kit.
Zeemax Power
Member #: 393
Oulton Park
fuck doing all that if you got an intercooler just put a T piece in near as you can to plenum
easy
http://www.Zeemax.com
t3gav
Member #: 229
Gavin@minispares.com
kent
phoned avonbar bout 4-5 weeks ago and they said their new bailey piston dv's with uprated seals will be ready in two weeks took engine out now so haven't rung bk are they ready avonbar? you wont here much of a noise at 4 psi though, get a bleed valve!
