Home > Help Needed / General Tech Chat > There\'s a whole in my Clutch Master Cylinder dear Liza, dear Liza,
battleroc
Member #: 5620
Dunstable, Bedfordshire
Hi
just stripping out my engine bay for my new turbo setup, and noticed clutch master cylinder has rusted and a tiny whole has appeared, so going to bin it and get a new one
I have a 95 spi with the metal body master cylinder. But a friend said I should replace with metro master cylinder as they have a better bore size so the peddle is a little easier on the foot
Should I go the metro route or replace same with same or I see those newer plastic types are available.
What are your opinions guys?
Cheers in advance
Dan
I must admit the double grey on the van feels significantly lighter underfoot than a grey does on my mini.
I'm not sure it's that easy. Id the pedal stroke on the Metro the same as the mini?
I just use the plastic type rather than the metal and they're fine.
battleroc
Member #: 5620
Wil is yours plastic for weight saving :)
No it's just I don't like metal!!
