| Home > Help Needed / General Tech Chat > ford crank sensor | |||||||
831 Posts Member #: 908 Post Whore gateshead |
21st Jul, 2011 at 07:04:49pm
anyone know how to test the crank trigger wheel pick up sensor for serviceability? think that might be the reason mine might not be starting. balls to the blower!!!
21st Jul, 2011 at 07:12:17pm
Plug in laptop, crank engine, see if it reads rpm - should be 200-300. |
21st Jul, 2011 at 11:20:10pm
it doesnt read any rpm when cranking. i am getting a spark on all 4 plugs but no matter what angle i set the static timing to, it wont fire balls to the blower!!!
21st Jul, 2011 at 11:21:54pm
No crank sensor = no spark.
21st Jul, 2011 at 11:24:48pm
yeah what Tom said,
22nd Jul, 2011 at 06:02:45am
hmmmmm bugger. thats that theory out of the window then. balls to the blower!!!
22nd Jul, 2011 at 07:36:33am
you would get a spark with no crank sensor, the edis would take over and run it at 9 degrees advance in limp home mode On 11th Feb, 2015 robert said:
22nd Jul, 2011 at 07:39:55am
Sorry Andy but you are wrong buddy. If the crank sensor isn't working the EDIS module does not know the engine is cranking or running, thus will sit there and do nothing.
22nd Jul, 2011 at 07:49:29am
Agreed. How could it spark at 9 degrees without a crank sensor. 9 degrees of what?
22nd Jul, 2011 at 08:06:58am
I'm thinking of when the edis looses contact with the MJ... too much beer last night.. On 11th Feb, 2015 robert said:
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
22nd Jul, 2011 at 08:31:49am
i would say you sensor is gone, maybe cut the wire & test you are getting power down into the sensor.
Edited by NickG on 22nd Jul, 2011. |
22nd Jul, 2011 at 08:49:04am
well, the leads can only go on 2 ways as its the wasted spark. tried swapping them over and over and over.. i have a canems set up fitted so the trigger wheel shouldnt matter. set up to #1 tdc and looked where the missing tooth was in relation to the sensor. 7 teeth after the missing tooth. set the canems to that on the laptop and tried it. nothing. then went round the whole 360 on the trigger wheel on the laptop, still nothing. it was running on a mj before i went to the canems and i havent adjusted the trigger wheel. balls to the blower!!!
22nd Jul, 2011 at 08:56:30am
Someone else has been having problems with trigger setting in canems recently
22nd Jul, 2011 at 11:36:16am
not sure if it does.
22nd Jul, 2011 at 12:07:00pm
On 22nd Jul, 2011 NickG said:
i would say you sensor is gone, maybe cut the wire & test you are getting power down into the sensor. This won't work as the sensor is a variable reluctance sensor and effectively generates its own signal. The only real was to test the sensor and EDIS is replace them with known good ones. Atleast this is the only way I have ever got results without scratching my head too much. http://www.twin-turbo.co.uk
22nd Jul, 2011 at 12:10:55pm
ah cool Ben! wish i knew that originally! was ages ago now. |
22nd Jul, 2011 at 12:16:51pm
You can test them if you have a sensitive multimeter set to AC volts. You see a small AC voltage from the sensor if you crank the engine that has a trigger wheel on with the sensor looking at it.
