Home > General Chat > Radtec Alloy Radiator
NickG
Member #: 7912
Australia oi oi oi!
what do you think of these uprated ones?
i need a allot rad with good cooling, you happy with them? they are very expensive
I got a second hand Minispares alloy rad that I'm very happy with.
Wintersurfer uses one of the cheapo Chinese versions with excellent results.
NickG
Member #: 7912
Australia oi oi oi!
it's for my swift gti mini, it has a morris 1100 rad in it a tiny bit bigger then a mini one nd front mounted but same as a mini.
it on heats up quick in traffic.
i could get a chinese one. not sure what to do.
NickG
Member #: 7912
Australia oi oi oi!
what is the wintersurfer doing power wise with the chinese version?
150ish hp
I run a Radtec and dont get any extra cooling from it
alaskanow0
Member #: 8466
Mansfield
Im running the Radtec extreme version. Its alot deeper and sits slightly higher. Mine only fits beacuse ive got a fiberglass front and have modified the the cowl to get it to sit 1cm lower. Seems to cool very well, Never had temps above 85oC with dry deck and 82oC thermostat. even on red hot days.
Edited by alaskanow0 on 23rd Jul, 2011.
