Home > Help Needed / General Tech Chat > tie bar and bottom arm lengths
my front suspension is miles out and i dont have any standard parts to measure
can someone recommend me a start point please *happy*
cheers
the tie rods should be 345mm from subframe mount face to centre of bolt hole on bott arms end, iv'e no info for bott arm lenghts
carl
cheers carl, tie rods are most important anyway imo
thinking about it though if i was to lengthen the bottom arm i would have to also lengthen the tie rod to keep all else the same yea?
jamie@thefatgarage
Member #: 9345
Sheffield
Yes, but a tiny amount, practically not measurable unless it's a big change. I was messing with mine yesterday while the subframe and engine was back off the car... but that is another story.
almichie
Member #: 2065
Minispares tell you how to keep the caster angle when fitting adjustable bottom arms and tie rods.
Found it...
http://www.calverst.com/articles/SUS-Suspe...adj_tie_rod.htm
Shaft seems nice and snug
carl i dont know where your measurements are from or too but it didnt look right once i got my measuring stick up to the tast *hehe!*
i did find this however
The standard length is 14 5/16" from the front of the locating washer to the nearest edge of the bolt hole in the adjuster block
ive set the tie bars to 14.5" the bottom arms set up by eye and then equalised left to right, with the aid of a plumb line ive measured them i dont have a clue what it all means *happy* but im reasonably happy now
my measurement works out 18mm or so less than that one you have there in inches, take off 15mm or so for lots of castor and i'm just about bang on,lol
dont know what the fook i was doing with your measurement then lol i remember thinking fook me thats nearly 2 inches out *happy*
( then again it was nearly 2 inches out *tongue*)
If you want to bring it round I can get it measured on all my gauges.
bennyy
Member #: 9037
Doncaster, yorkshire
Brett if you need measurements of anything pop round buddy.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Can you check his length for him? *wink*
bennyy
Member #: 9037
Enough of that the other night, bret wanting a go with your tool and all that. *wink*
wil cheers for the offer, it might be some time in the future though
trust andy to have a tool that you have to squeeze and pull for it to work *happy*
I thought you where both very impressed with my tool
i must admit playing with your tool the other night had me quite amused with its auto stripping action *happy* *happy*
bennyy
Member #: 9037
Yes but its not you that has to clean up the mess on my driveway from andys tool *wink*
Edited by bennyy on 28th Jul, 2011.
Yeah, but I'm sure you'll get a bit of pleasure from the mess me and Brett left behind!
bennyy
Member #: 9037
Cleaning up the mess was worth tuesdays events
I'll teach you a little about wiring when we finish it of, then you can do it yourself next time.
bennyy
Member #: 9037
Cheers andy, no more lawnmower cable *happy* lol
or potential fires!
or potential fires!
potential? looking at the old loom there had been many fires lol
bennyy
Member #: 9037
non in my ownership *happy*
you'd been lucky then
