Home > General Chat > Bearing Supply Problems?
All,
Today tried to order some mains and big end shells in std/std sizes, tried a couple of the larger well known places and apparently the shells in that size are in very short supply at the moment??
Has anyone else come across this??
After a bit of shopping today I have got everything together to build the engine apart from the bearings.........
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
try your local engine place... always easier than mini specialists!
Alex
AlexF
Yes might give that a try tomorrow.
Just a bit wary of being sold crap......
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
buy AE ones :)
Alex
AlexF
Well there is the question, do you buy AE or vandervell??
Any opinions??
wilko26
Member #: 477
Cirencester
I also had trouble getting hold of std size vandervell engine bearings the only place i found that stocked them was avonbar.
Tom, I've always used AE and never had a problem as such.
D
I got mine from avonbar
8PortChris
Member #: 246
Cumbria
Vandervell have changed the material that there made from.
I dont know if it was a temporary thing or not, but when i got a new crank, Nick Swift supplied me with shells from an Australian company ( cant think of the name ), cos the vandervell ones where no longer upto the job.
Chris
mikemph
Member #: 449
Oxford
Yeah morspeed are selling a new name bearing meant to be good
AE are up to the job then, right will have a ring around tomorrow then...........
I have got an AE oil pump I bought some time ago, it appears to be the same as the Avonbar type, with "Powerflow" cast into the pump casing. Any ways to check if it is the pukka item? It has the oil ways cast in the correct (OE) positions, and also has a steel back cover......
Just as an update, sourced some Vandervell HD type today from Avonbar.
did you get your turbominis discount
Bollocks
Forgot all about even asking for it
What a tw@t
yes the discount tom...........................
i uset to get my bearings some years ago from edmunds and walker wheetley hall road doncaster
they should still be going!!!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I thought E&W went bust YEARS ago?!
alex
AlexF
