Home > General Chat > Crank Nitriding £25
I am getting the crank on the TT2 nitrided in the next few weeks. The cost is by weight and there is a minimum order of £52 +VAT. For this I can get 2 cranks done.
If anyone would like to join me for £25 let me know.
Of course the problem is collection and delivery to me. The place is in sheffield, so for those between York and Sheffield I can pop by on my way down. for others it may not be so cost efficeint.
If no-one is interested I'll just chuck another 998 crank in.
Wil
01smartc
Member #: 2563
Tamworth
Does it need regrinding after you had it treated?
Chris
Don't need one doing at the moment Wil. But may be interested in having 1 or 2 done in the future.
No, you need to polish the journals back up, but not grind.
Not 100% on how I'll do this at the moment, got a machinesist to do it last time.
I've got one that needs doing andi'm near sheffield *smiley* count me in
topcat
Member #: 9408
Tiptree, Essex
Typical, I just sent mine off last week to be done at a lot more than that :(
www.topcatcustom.co.uk
Sorted. I work out the polishing issue once done.
I'll PM you some details.
Polishing is easy, just drop it in the lathe and use emery.
That was my plan to be honest
Or if your names carl austin you use the sheer roughness of your index finger!
If you want to call here on the way back from the Nitriders in Sheff Wil and use my lathe you are welcome.
That's a vey kind offer, I'll let you know. a mate round the corner has a lathe, but not sure a crank will go in it.
Could probably get one in my lathe, but chances are it will be bent when you take it out again...
I thought it had to be a EN40 crank to be nitrided. Not?
No. If you use EN40 or EN41 you get a minimum 0.4mm thicness. If you have other stees, such as EN16, you ger a maximum of 0.4mm.
And something is better than nothing.
The EN16 crank I previously had done worked well and 10 years on has no wear.
What about tuftriding?
Pass
Found this:
http://www.crankshaftco.com/steel-crankshaft-hardening.html
Interesting.
