Home > Help Needed / General Tech Chat > MPI SRS light on
gents,my MPI mini SRS light stays on will not go out any thoughts ? *smiley*
Has it been in a bump, the SRS unit once activated cannot be reset, or so I am told.
Is everything plugged in that should be, seatbelt tensioners, airbag?
wng691s clubby
Member #: 9252
Cleethorpes
from what iv read there quite a list that it could be:
Letting battery drain too low
Bad Sensor
Blown fuse
Unplugging the car’s battery
Removing the gauge cluster/installing aftermarket gauges
G-Force sensors
Bad clockspring (located inside your steering wheel)
Bad ECU
Bad reverse light switch on transmission
Car was in an accident
Airbag defective/unplugged
hope it helps
Done now needs redoing lol
Check all the above Steve. You could go to an ex-rover dealer and get it plugged in. Or take the bulb out *wink*
evolotion
Member #: 83
Glasgow, Scotland
on some rovers you can bridge a few wires in a connecotr under the dash and get flash codes out the SRS, is this possible on the minis? may have jsut been the honda-rover cars.
Denis O'Brien.
oh dear will have a look and report back thanks for the advise gents
found the problem a dicky plug to the air bag at the back of the colum................... well on to the next fault now the rear washer pump no live there ?
Should be a 12v feed to the stalk on position one of the ignition, then back to the connectors to the rear loom on the bulkhead. might have a fuse on the mpi.
well its a duffed stalk, this has more faults than any car i have ever worked on ............... one by one
the MGF stalks fit iam "stalking" one on ebay as i type
wng691s clubby
Member #: 9252
Cleethorpes
thats was bad steve
