| Home > Help Needed / General Tech Chat > Help me help t/dave gearbox dismantling | |||||||
5th Apr, 2005 at 07:55:50pm
I gotta big socket and some bars but the pinion nut is ether v tight or l/h tread ?? Would a impact driver be easier.
5th Apr, 2005 at 08:18:05pm
Tight.
Edited by turbodave16v on 5th Apr, 2005. On 17th Nov, 2014 Tom Fenton said:
![]() 2641 Posts Member #: 19 Post Whore newcastle |
5th Apr, 2005 at 08:18:14pm
if the box is off engine .... get a xantia .... put suspension to highest setting ... put box under sill of xantia upside down , lower xantia onto box ........ use big fook off bar on socket and nut WILL come off. Everyone knows that instructions only have to be read if the thing doesn't work....
5th Apr, 2005 at 09:06:00pm
and what if you dont have a xantia... |
5th Apr, 2005 at 09:15:57pm
On 05/04/2005 20:18:14 minimark said:
.... get a xantia .... Ha ha ha ha superb!!
5th Apr, 2005 at 09:16:00pm
hire one or get the jack out and use mates car Everyone knows that instructions only have to be read if the thing doesn't work....
5th Apr, 2005 at 09:18:08pm
Or in fact if you are not flush enough to afford a Xantia for your tool box then get a BX instead they are much cheaper and if you fancy a laugh can be driven round the block with one of the rear wheels missing and the suspension on high.....
5th Apr, 2005 at 09:18:34pm
Think it will go down the garage tommorrow for a windygunning or stick it under the lift ramp
5th Apr, 2005 at 09:20:13pm
Best start a new topic 101 uses for a xantia
5th Apr, 2005 at 09:26:19pm
1. tow car Everyone knows that instructions only have to be read if the thing doesn't work....
5th Apr, 2005 at 09:27:11pm
2.show the bling boys how low u can go Everyone knows that instructions only have to be read if the thing doesn't work....
5th Apr, 2005 at 09:28:34pm
3. Confuse the bird at the McD's drivethrough by making the suspension go up and down as you are placing your order for sh1te food
5th Apr, 2005 at 09:29:24pm
4.show the 4x4 school run lot, that my ?350 xantia has more ground clearance than there ?35K 4x4 . Edited by minimark on 5th Apr, 2005. Everyone knows that instructions only have to be read if the thing doesn't work....
5th Apr, 2005 at 09:30:33pm
5. drive over full height kerbs to bag the last parking space at the cinema much to the annoyance of the kid waiting to drive into the space the "normal" way
5th Apr, 2005 at 09:31:57pm
6.mobile skip ( estates only ) Everyone knows that instructions only have to be read if the thing doesn't work....
5th Apr, 2005 at 09:33:12pm
actually did the parking thing at asda one xmas , didn`t half pis everyone off waiting the q to get into car park ... Everyone knows that instructions only have to be read if the thing doesn't work....
5th Apr, 2005 at 09:34:34pm
7.touch parking world champion ( tow bar class ) 4 years running ... Everyone knows that instructions only have to be read if the thing doesn't work....
5th Apr, 2005 at 09:36:13pm
Have you tried the 3 wheeler thing? It does actually work believe it or not!
5th Apr, 2005 at 09:36:48pm
8. Good source of front mounted intercoolers to convert 306 turbo diesels from top mounted intercooler
5th Apr, 2005 at 09:42:35pm
lost a frontwheel on the coast road at 55 ish , front end dipped then self leveled and ran on one wheel and one disc !!!! came to a safe stop , got out and when back up road and got my wheel !!!! flatted one part of disc but no body work damage .lol Everyone knows that instructions only have to be read if the thing doesn't work....
5th Apr, 2005 at 09:44:11pm
Hmm a bit more of an extreme experiment than I tried......!!!!
