Home > Help Needed / General Tech Chat > Running pipes & cables inside the cab,
analogue_radio
Member #: 4600
Melton Mowbray, <BR>near Leicester
I've removed the tabs off the underside of my mini to reduce the chance of rust & to move the fuel/battery/brake lines inside to protect them & keep them clean.
Just want to see where they enter & exit, how they are secured and what pipes you've used.
Cheers!
rubber lined 'P' clips
I use braided fuel ines, as MSA regs and normal brake pipe.
For a road car I trnd to keep everythong out side as it's much easier and stopps people standing on stuff. the race car has it all inside. this is a good idea in rally cars, but for hillclimbing I think it's more to look the part than anything else!
I removed those tabs too. I kept all the fuel lines and bettery cable on the underside, and run the brake line on the inside, since thats the one that is held by tabs on the later cars. The fuel lines use plastic clips anyway.
sturgeo
Member #: 1778
Northants
If you do run the fuel lines internally, make sure you get Teflon hose as it stops the fumes unlike the normal braided stuff.
analogue_radio
Member #: 4600
Cheers for the pointers!
Anyone got any photos?
analogue_radio
Member #: 4600
Going back to this again.
Shell is back from paint so running these lines is something I need to do first.
Can someone provide a link to the correct fuel pipe? unsure of the required diameter.
Thanks.
I'm using these clips for brake and fuel lines:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=220913460129
The fuel is going in this stuff:
http://www.ebay.co.uk/itm/110644365460
Standard copper for the brake lines.
analogue_radio
Member #: 4600
Double checking before buying, this would be alright yeah?
http://www.demon-tweeks.co.uk/motorsport/f...ssure-fuel-hose
That's rubber low pressure hose!
The rubber will 'breathe' fuel vapours, teflon or ptfe lined is what you shoud be looking for, or the car will always stink of fuel. The low pressure hose bit might be ok, but for the extra saft margin, the high pressure fuel injection hose will be better
analogue_radio
Member #: 4600
Oh apologies, wrong link, they also sell a high pressure hose as well!
I'll have another look round.
FYI
http://www.gates.com/common/downloads/file...echtipsform.pdf
analogue_radio
Member #: 4600
http://www.ebay.co.uk/itm/6-8mm-5-16-Stain...65#ht_773wt_982
Yeah yeah?
analogue_radio
Member #: 4600
I hate to keep nagging, but can anyone in the know confirm the above Ebay link is the right stuff for the job?
wez
Member #: 9271
Stoke on Trent
it says it PTFE (teflon), unless someone's actually bought and used that specific item from ebay, you can only go from the description.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
analogue_radio
Member #: 4600
Very true! Looks and reads to be up to the job so I'll give it a go, cheers.
That seller is a top bloke i have lots of bits off him in the past.
As for that hose you will need to buy His fittings as they are the only ones that work with that hose.
analogue_radio
Member #: 4600
Good to hear! ordered it last night.
& ta for that information mate, will keep it in mind for when i get to that stage.
How much did you order?
analogue_radio
Member #: 4600
4m
