| Home > Help Needed / General Tech Chat > ARP head studs Q | |||||||
10th Aug, 2011 at 07:49:20am
ARP make studs for shaved heads and non shaved heads as they call them. I've got a set of non shaved ones that bottom out in the block before the UNC threads are fully covered. What do we think of using this?
10th Aug, 2011 at 08:11:35am
Iv'e found there is usually wnough spare space in the bottom of the hole to tap a couple more threads in there, so that is what i would do,
10th Aug, 2011 at 09:12:25am
I don't have a bottom tap I think... Lets try.. On 13th Jul, 2012 Ben H said:
10th Aug, 2011 at 09:52:29am
On 10th Aug, 2011 Vegard said:
I don't have a bottom tap I think... Lets try.. On 28th Aug, 2011 Kean said:
10th Aug, 2011 at 11:44:40am
Have you checked your ARB big end bolts yet? On 26th Oct, 2004 TurboDave16v said:
10th Aug, 2011 at 11:01:31pm
Colin. The bolts seem to have seated fine I must say. I'm running them as is.
10th Aug, 2011 at 11:09:35pm
i hope you didn't run a UNF tap down there or you are on big trouble,lol |
10th Aug, 2011 at 11:14:55pm
Oh Vegard, I really am surprised!!
11th Aug, 2011 at 09:31:46am
It says make sure, I did...now On 13th Jul, 2012 Ben H said:
11th Aug, 2011 at 09:56:24am
I have threads above the block deck with the BMW ARP studs on the race engine Vegard. Was not a problem according to Pål and the guys he ordered them from. |
30th May, 2012 at 08:49:24am
I must admit, I ground then down.....
30th May, 2012 at 08:51:38am
30th May, 2012 at 08:53:34am
45ft lbs Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
