| Home > Technical Chat > CO2 cooled inlet manifold | |||||||
6th Apr, 2005 at 08:58:10pm
Was thinking about this last nite,maybe laughable/might work.....
6th Apr, 2005 at 09:11:32pm
i was thinking this a while ago although using a fire extinguisher! much cheaper |
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
6th Apr, 2005 at 09:15:34pm
think it might work to use say a heater matrix a seperate leccy water pump from another car and just plumb it in that way it must work to cool it down but think you would see an advantage?
6th Apr, 2005 at 09:17:10pm
nope, water will retain too much heat on a hot day. then try find space for a rad etc |
6th Apr, 2005 at 09:54:04pm
I'm not going to say it'd unlikly have an effect on charge temp, as it definately will lower the temp; How big a benefit i'm not sure however...
Edited by turbodave16v on 6th Apr, 2005. On 17th Nov, 2014 Tom Fenton said:
6th Apr, 2005 at 10:10:30pm
"Spraying it onto the intercooler mind.... "
AlexF |
6th Apr, 2005 at 10:35:19pm
Just make sure you use a C02 and not a dry-powder extinguisher! On 17th Nov, 2014 Tom Fenton said:
7th Apr, 2005 at 09:52:58am
We ran a water spray on the intercooler at avon park last year. Didn't seem to make much difference. Might try a slightly different design this year. The problem last year was trying to hide it, I dont think they like you spraying water on the track! http://www.twin-turbo.co.uk
7th Apr, 2005 at 10:44:54am
It depends how hot your IC gets I guess!
AlexF |
7th Apr, 2005 at 11:07:49am
I'm off to the scrap yard on Saturday to hopefully get some air temp sensors. Might not get to fit them before the next event though.
7th Apr, 2005 at 12:12:00pm
I've thought of this also, my ecu can also do this, my IC are quite low with the new intercooler, lets see what there like when I wind the boost up a little Team www.sheepspeed.com Racing
7th Apr, 2005 at 02:38:48pm
Ben,
8th Apr, 2005 at 08:35:22am
The problem I have with the temp sensor is that the megasquirt can be a pain in the arse. It supports, in theory, any sensor. Basically you just scale the sensor in the software. We have not had much luck with rescaling sensors however, so I am trying to get a standard GM part that is what megasquirt was designed around. I was planning on getting various ones from the scrap yard, mainly Vauxhals, and see if one matches the GM charateristics. Then I will probably order some new ones. You can get the GM part new, but it is expensive and has a very strange connector that is almost double the price of the sensor its self.
![]() 725 Posts Member #: 177 Avon Park 2006 Class D Winner Woburn Sands |
8th Apr, 2005 at 08:38:19am
I tried spraying co2 on my intercooler last year, but had two false starts, so it was a waste really, but I did feel a difference when I pulled off.
16V project underway |
8th Apr, 2005 at 08:55:57am
how do you stop the C02 from going in your air intake?
8th Apr, 2005 at 09:52:13am
So long as your below about 65 you should be ok in terms of engine safety....
AlexF |
8th Apr, 2005 at 10:02:06am
what should it be for max performance? Team www.sheepspeed.com Racing
8th Apr, 2005 at 10:10:27am
Double posting... Edited by Vegard on 8th Apr, 2005. On 13th Jul, 2012 Ben H said:
8th Apr, 2005 at 10:10:28am
Wouldn't that be as cold as possible so to speak?? It really depends on what the car is fuelled in at I guess. If you have it RRed at 50degrees, and you use -273,15 degrees I guess it'd run lean... Not to mention carb icing..
8th Apr, 2005 at 10:45:11am
From a performance point of view I would say the colder the better. My plan is to do runs down the strip using the spray and not using the spray. Log the temperatures and see how much effect it has. Only worthwhile on a hot day I would have thought though. http://www.twin-turbo.co.uk
8th Apr, 2005 at 01:21:30pm
65 is a little too warm methinks...
8th Apr, 2005 at 02:15:13pm
When we first buit the turbo I put some probes before and after the intercooler (this was the GT 5 one we had tucked away) I seem to remember air temp in was 95 and out around 35 to 40.
8th Apr, 2005 at 02:20:20pm
65 degrees C is a typical temp most OEM maps begin to retard ign timing to protect the engine.
AlexF |
8th Apr, 2005 at 03:48:41pm
So it's not ideal is it.
8th Apr, 2005 at 03:57:21pm
The GM sensor is
