Home > General Chat > Broken Water Pump
Anyone had a pump break like this before? It buggered my weekend at Loton Park.
nope, never. thats one piece. although it is only pressed on. I broke 3 water pumps on the weekend, (trying to turn down the impellors) but not like that
hell! not where you would think it would go.
fan belt too tight is the only think I can think off, or maybe the shaft was bent putting to much strain on things? dunno???
I don't run an alternator, so I have to squeze a belt on. It is quite tight I guess.
It's lasted 3 seasons before it bust.
Just another thing to put on the list of things to check for wear every winter.
Wil
wil I used to run autograss minis with no alternator, the way I did it was to dismantle an old dynamo right down to the bare bones and then modify the end case to give me basically a tensioner wheel to use with a std length belt? Did not weigh much at all by the time I had done it, I used to squeeze a short belt on like you say but had problems with it jumping off once or twice hence I moved to this set up.
jeez Wil/Ben.
How do you break stuff no-one else manages to?
First the pot joint burst in two, now the water pump!
Any others we don't know about? LOL!
Yeah Tom I've had problems in the past with the belt being thrown off. It turned out that the pully was buckled, never thrown one since the new pully has been fitted.
What else have we broken.....
I broke me banjo once, that was embarasing!
banjo as in banjo string?
Aye you don't want to break that, it hurts........ *surprised*
twang!
AAAARRRRGGGHHHHHHHHHHHHHHHH!!!!
F F- FF- F FFFF- FFUUUUUUUUUOOOOOORRRRRKKKKKKK!!!!
t3gav
Member #: 229
Gavin@minispares.com
kent
kad do an eletric one meant to increase power and torque by 2-3 bhp/ftlbs pos more on a turbo, anyone use one?
On 07/04/2005 21:51:12 gav said:
pos more on a turbo
Well that's a load of bollocks - why would a turbo make more power/torque than a nat-asp when an electric pump is fitted?
Electric water pumps aren't new. Miglias have been using them for a while. Can you afford one? Have you pursued EVERY other power-making avenue such that finding another 1, 2 or 3 hp is becoming a real challenge? If so, an electric water pump is ideal.
If not, spend the money on something else that gives better hp/?
Just to explain, the electric water pump cannot create any power, it only releases the power consumed by the mechanically driven pump.
Therefore Daves comment that turbo/NA would not make any difference as they both use the same pump arrangement.
We looked into an electric pump, but without an alternator I get worried about power consumtion. also with the side rad i'd still need to run a fan so it's easier just to run the mechanical pump.
Wil
I'm running an electric water pump this year, I'll let you know how I get on.
