Home > General Chat > Block, Head & Gasket diagnostic
Simon
Member #: 1865
Norwich, Norfolk
I've posted previously that my car gets a touch warm on track days and it did overheat. a recent run showed that it was getting a bit warmed than previously just on the road and was suggested the gasket might have been compromised after the overheating.
So today I whiped off the head and here are the pictures, let me know if you see anything untoward. There are a few drops of coolant on the block, head & gasket but might just have come from dismantling it, although the engine was drained of coolant a week ago.
I have included a link to some super hi-res versions of the images, 6mb each.
hi-res (6mb): http://www.web2o.co.uk/mini/DSC_4497.JPG
hi-res (6mb): http://www.web2o.co.uk/mini/DSC_4500.JPG
hi-res (6mb): http://www.web2o.co.uk/mini/DSC_4502.JPG
hi-res (6mb): http://www.web2o.co.uk/mini/DSC_4503.JPG
hi-res (6mb): http://www.web2o.co.uk/mini/DSC_4504.JPG
Edited by Simon on 16th Aug, 2011.
I'm no eggspurt but looks like there may have been some coolant seeping around the back end of the block. Perhaps by too little torqueon the rear studs.
One bonus. Whilst your head if off get the chambers and the piston dishes measured to work out your CR.
You gonna be back on the road for the RR day? *smiley*
Simon
Member #: 1865
Norwich, Norfolk
All that 'wet' at the back of the block is oil which I would say got there while removing the head.
Indeed I will now be measuing the pistons and chambers, abuy guides on how to do this easily?
I'll be back up an running this weekend if the new gasket turns up so I dont see any issues with the RR day.
A burrette an old CD and some oil.
check the block for flatness using a steel ruler and feeler gauges. and the head ......... my monies on the head gasket has not been torqued up correctley on the initial build ..........
the mixture is burning correctley in the head..... now worries there *smiley* *wink* .... fit a new BK450 head gasket use another torque wrench known to be good torque to 55ft pounds
if it still overheats and you are not loosing oil or coolent .....some blocks run hotter than others due to internall rust build up over many years ......... yours could be one like that ?
also ignition too retarded also to suite your engine spec ..................... hope this helps *smiley*
Edited by BENROSS on 16th Aug, 2011.
Simon
Member #: 1865
Norwich, Norfolk
thanks benross, i'll be checking for flatness this evening when i get out there. so ignoring the overheating issue for the moment everything else head/block wise colours & carbonation etc everything looks normal?
i'm pretty sure my torque wrench is accurate, BUT, at the time of building I would only have torqued down to 50ft pounds going by the haynes manual. EDIT, actually it might have only been 45ft pounds as stated by the ARP instructions.
in terms of retarded ignition, i know that there it room for a bit more advance so it could be time to adjust this sooner rather than later. that might make sence as its idles nice and cool and even after 20mins just on idle the temp is perfect so perhaps it is the timing further up the rev range.
you have too much advance up to 80 kpa pm john and use the map what john and andy run in the van theres no issues there with det or overheating
whats the ccs in the piston dish and ccs of the the engine? it looks to me some one squeesed 26cc in the head chambers
Simon
Member #: 1865
Norwich, Norfolk
how can you possibly tell thats 26cc just from looking at it! *surprised*
I have only just been out and measured as I didnt know prior to removing the head today.
That 'someone' would be mr Morson, 26cc head, 13cc pistons, 1380cc engine.
http://www.turbominis.co.uk/forums/index.p...d=170151&fr=100
bennyy
Member #: 9037
Doncaster, yorkshire
he is a genius maybe?
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Well, if it's from Morspeed and says 26 cc it's more likely to be 23.....
simon *wink*
well if your pistons come to the top of the bores and the decs have been flushed your compression ratio is 8.37:1 ..just right! *smiley* for a well powerd motor with a good intercooler and the right map and your up there 180 bhp+ depending on the rollers ?
dont for get to PM john on that map *wink* *Yes*
Edited by BENROSS on 17th Aug, 2011.
tadge44
Member #: 2500
Buckinghamshire
Benross, care to hazard a guess on my HP
figure ?
1275cc MG Metro NA cam 8.2 CR GT17 Turbophil head normal valve sizes, Punto GT intercooler 17psi
Could generally be crud buildup in the engine like steve said, the 998 i had in my car i couldnt keep any lower than normal temp, always got warm, this engine i cant actually get to run at normal temp, even if i thrash the beans off it on the motorway and sit still in traffic. Just one of those things i guess.
figure ?
Very close to what the van puts out I reckon Dave! 170nana's I'd say.
depends on whos rollers david ? whats your compression other factors etc......etc i havent a cristal ball .....but a guess is 160 bhp ..........................................? havent a clue
are you bragging *hehe!*
