| Home > Help Needed / General Tech Chat > Identifying disc setup | |||||||
249 Posts Member #: 513 Senior Member Sheffield |
7th Apr, 2005 at 03:17:32pm
Im not sure what sort of setup this is could anyone help. Im guessing its a metro setup as when i bought the car many moons ago it had had a 1275 lump dropped in. |
7th Apr, 2005 at 03:23:36pm
8.4" Solid discs with 2 pot calipers as fitted to all Minis from 1984 onwards :)
7th Apr, 2005 at 03:25:58pm
Oh if it helps the front of the caliper reads;
7th Apr, 2005 at 03:33:40pm
Ah thats that then, thanks for the swift reply! was hoping they were metro the cars a 72' so someone obviously grabbed the engine but didnt bother with the brakes for whatever reason. Lazy sods!
7th Apr, 2005 at 03:41:51pm
I would say if they were not great with a 1275 they might be a bit marginal with a turbo. Depends on the condition of what you have got really, I have used this brake setup in the past with a well tuned 1293 NA engine, a set of fast road type brake pads will transform them, although they will always suffer from fade if used hard as they are not vented discs. More than anything else make sure they are in tip-top condition, make sure all the pistons are moving and are not seized (more common than you might think) and also make sure the pads slide freely in the caliper body. Finally bleed the system with some good quality brake fluid.
7th Apr, 2005 at 03:42:17pm
they shall be fine mate, make sure the pads and disks are ok Team www.sheepspeed.com Racing
7th Apr, 2005 at 09:38:14pm
yeah will be fine with good pads and discs. and obviously everything else tip top |
8th Apr, 2005 at 12:08:39am
I've never done anything with the brakes before so you'll have to pardon my obliviousnessness but what would i require to convert to braided hoses. Im guessing just change the hoses and fittings and keep the master cylinder? |
8th Apr, 2005 at 12:39:44am
Just undo the fittings to the rubber hoses and replace with the braided ones. Just the same as replacing a rubber one with another rubber one, except you are replacing rubber with braided.
8th Apr, 2005 at 01:10:30am
Just noticed iains sticky post about hoses and carb rebuild kits, would these suit? It's just gonna be road going so probably wouldnt bother doing the lot if it's going to get too expensive.
8th Apr, 2005 at 01:40:46am
Yes
8th Apr, 2005 at 02:19:27am
Cheers for the info bud
8th Apr, 2005 at 02:38:07am
With the brake set up you have got, you can re-use the hubs and driveshafts with S discs, S drive flanges and S calipers.
Edited by Tom Fenton on 8th Apr, 2005.
8th Apr, 2005 at 03:38:35am
Makes sense mate deffinately a good point. I think it could deffinately be an option just pricing up on minispares for discs/callipers and flanges come to about ?280, which isnt too bad i suppose.
Edited by andygardner on 8th Apr, 2005. |
8th Apr, 2005 at 03:49:43am
Not sure what they go for these days but when I bought a Cooper S disc setup I paid ?185, the discs were knackered, and one of the calipers had been 'modified' with the aid of an M12 bolt where the bleed nipple had obviously been sheared/stripped in the past.............
8th Apr, 2005 at 04:07:40am
By the looks of things on ebay they're still going for that kind of figure... at least. I really fancied 10's so reckon ill still go for the S setup at some point. Seeing as the current setup is working ill stick with that and get the rest of the car finished then see if theres enough left over for the S setup.
8th Apr, 2005 at 07:48:36am
yeah if you need braided hoses give me a shout |
13th Apr, 2005 at 08:16:12pm
Just to confuse things there is also the option of modified fiesta brakes and even modified mg metro items. check out some of tha other threds
14th Apr, 2005 at 01:15:25pm
Have you considered something else ?
14th Apr, 2005 at 01:47:39pm
14th Apr, 2005 at 01:49:36pm
But looking at it, isn't that caliper the wrong way up? E.g. Bleed nipple at the bottom? From the disc shield the steering arm is to the left of the picture at the top?
18th Apr, 2005 at 12:28:27pm
Ah, clever chap, most observant ! Yes indeed. This was a practical joke to local youngsters who feel that mini disc setup is too expensive to buy and are ready to use drum brake hubs, disc from make X and caliber from make Y, do the necessary adapters etc etc. I uploaded the pic to show that (almost) everything is possible given enough madness. These calibers are currently fitted in my Morris Minors and yes the bleed nipples are now pointing upwards. BTW, these calibers would have just fitted inside 13" Mini wheels. |
