| Home > Technical Chat > turbo to manifold, which nuts? | |||||||
17th Aug, 2011 at 11:37:42am
The four nuts that bolt the turbo to the manifold, whats the best nuts to use and where can i get them from?, mine seem to have worked their way loose, two have fallen off:( done the search with no results. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
17th Aug, 2011 at 12:01:16pm
http://www.ebay.co.uk/itm/Uprated-Exhaust-...8#ht_500wt_1156
17th Aug, 2011 at 12:13:18pm
Never used anything but standard stainless metric nuts. Never had one come loose. |
17th Aug, 2011 at 12:18:16pm
They are often called aero nuts in the UK.
17th Aug, 2011 at 12:55:44pm
i'm the same use stainless nuts and spring washers on the mini without any issues but they work loose on my nissan so swapped for those locking type. On 20th Oct, 2015 Tom Fenton said:
17th Aug, 2011 at 01:01:13pm
http://www.nasbolts.co.uk/acatalog/copy_of...ure_K_Nuts.html On 26th Oct, 2004 TurboDave16v said:
17th Aug, 2011 at 01:03:41pm
£3.50 + VAT each, that's fooking nuts! Edited by wil_h on 17th Aug, 2011. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
17th Aug, 2011 at 01:07:46pm
17th Aug, 2011 at 01:17:52pm
On 17th Aug, 2011 wil_h said:
£3.50 + VAT each, that's fooking nuts! Especially when you take into consideration what a nutter the seller is... On 13th Jul, 2012 Ben H said:
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
17th Aug, 2011 at 01:18:20pm
17th Aug, 2011 at 10:26:43pm
I had stainless on, i think the high temps and differing grades of steel worked them loose, found one of them on the turbo bulhead box, turned blue with heat. I'll bite the bullet and get the proper ones this time, its a right pain to strip apart just to replace them. Once again i'm in your debt gents. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
![]() 489 Posts Member #: 9159 Senior Member Devon |
18th Aug, 2011 at 07:15:15pm
http://www.ebay.co.uk/itm/5-16-UNF-K-Nuts-...=item35b412cb25
