Home > General Chat > gearbox builders
t3gav
Member #: 229
Gavin@minispares.com
kent
just wondering how much the main companies charge on building
gearbox's without parts for example avonbar charge ?1650 for sccr with sc drops and quaife lsd but is this good or do they put a lot of money on labour, is there anyone on her who can build my box cheaper?
Well it'll be new bearings, and cleaned/inspected other parts...
TBH - I bet they make very little - maybe ?100 or so on the assembly. Fact is, they're makign more than that on all the parts you're buying from them. They could build it for free and still be making money...
tip - minispares do gearbox rebuild kits - all new bearings and gaskets.
Price up one of these, along with all the other parts you're looking at, and see what it comes to.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
As soon as you go to a LSD, you need to machine the casing and that takes a fair bit of time...
The rest is as dave says!
Alex
AlexF
t3gav
Member #: 229
kent
are lsd's that much better than a x pin diff for the money
Wht you want - lots of trackday use?
If so, they are better than an 'open' diff...
Drag-strips?
I've never run one - but get equal/better (?) 60ft times to the other 'quick' guys on here, so i'd say not... But that assumes your suspension is set up properly...
If it isn't, and LSD will send you into the wall, or drag you up the track...
oh - forgot one...
General road use?
Probably not notice the difference between an open diff and a quaife when parking / low speed manouvering, but a trannex, or other plate diff will be a lot heavier.
Edited by turbodave16v on 7th Apr, 2005.
Depends what you want from the car. X pin diffs are a lot stronger and more durable than std. LSD's will transform a high powered car by controlling wheelspin and giving more traction.
LSD's are approx 4+ times the price of a x pin.
t3gav
Member #: 229
kent
ah think i might just get a x pin then cheers, can spend the money elsewhere then
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
x-pin on road for me...
lsd for track
(eventually!)
Alex
AlexF
The quaife is a great diff, got one in my 205 track car. However I wouldn't recommend one for everyday use over high mileage, due to the design they do wear themselves out over time.
t3gav
Member #: 229
kent
cheers guys
My LSD is a four pin. Confusing?? :)
Quaife's dont need any gearbox machining so ive been told *smiley*
The Tran-X does indeed...
You cannot really see in this picture though. I've used Ford flywheel bolts for the LSD, as these have got much "lower" heads.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I was told they did *indifferent*
AlexF
I thought it was the latest jacknight ones that didn't and the rest did. I have todo quite a bit of work to get my tran-x in. thanks to Jon flan the man for his help
its always the same, everyone hears different *happy*
ive got no experience so am only going on hearsay!
so far for sure we know trannex ones do *smiley*
Yep ! Got the bolt heads machined down on mine, this meant i didn't have to take quite as much of the casing away.
Phil. *smiley*
Dangerous
Member #: 417
Are them equal length driveshaft kits any good ??
dan
Member #: 93
guy at work has got them (see link below)
http://www.pistonheads.co.uk/members/showCar.asp?carId=1509
if i see him next week i'll have a word,
also try doing a search as td did some calcs on torsion of the standard length of shafts and came to some interesting conclusions...
n.g.l.
Member #: 181
Chard, Somerset
The gearbox casting does most definately need machining/modifying to accept the Quaife lsd. I've just had to do the job myself. As for the JKD equal length driveshaft kit the man you want speak to is Turboharry, he is the only guy that I know of who's running one on his turbo mini.
ASK Hogster he does my gear boxes, say no more*wink*
turbo hogster
Member #: 178
stowmaket suffolk
all ready in touch thanks for the plug mate.
T3Tone
Member #: 252
Sunny suffolk
Can also recommend hoggys gearbox rebuilding skills, i think you should start your own buisness m8.
The SC/CR Hog box.
-MINI CLUBMAN 1380 TURBO-
turbo hogster
Member #: 178
stowmaket suffolk
now theres a thought, the hog box does have a certain ring to it lol.
