| Home > Help Needed / General Tech Chat > Mini\'s Ride is too harsh - how to fix? | |||||||
Site Admin 6301 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
20th Aug, 2011 at 11:50:57am
Hey chaps.
20th Aug, 2011 at 11:56:50am
A minitastic spring kit... Or hydro like me :) I run a supercharger and I don't care the TB is on the wrong side.
20th Aug, 2011 at 12:00:34pm
Won't that allow the tyre to rub again? |
20th Aug, 2011 at 12:04:55pm
If it aint rubbong you aint dubbing....
20th Aug, 2011 at 12:06:20pm
I have already raised it by about two inches higher than I want.
20th Aug, 2011 at 12:11:32pm
My old mini rubbed like hell on the front, the back was about an 1.5" higher than the front handeled well a little twitchy breaking hard in the wet but it made it more fun lol. Or can you trim the rear arches a little? Drives
1050 Posts Member #: 764 Post Whore Staffordshire |
20th Aug, 2011 at 12:26:22pm
bump stops front and rear? |
20th Aug, 2011 at 12:44:24pm
Just took it to get some petrol - the front end is actually fine- not harsh no crashy bangs and no rubbing. So, it's just the rear end. |
20th Aug, 2011 at 12:59:08pm
If it is rubbing then either raise the ride height or have the arches tubbed so it will run low without rubbing.
857 Posts Member #: 1778 Post Whore Northants |
20th Aug, 2011 at 01:02:17pm
What wheels/tyres are you running?
20th Aug, 2011 at 01:20:34pm
10x5 wellers atm, with yoko jobbies. not too wide and not a crazy offset. It's not rubbing on the plastic arches, but the car itself, only over harsh bumps.
272 Posts Member #: 9125 Senior Member Sheffield, South Yorkshire |
20th Aug, 2011 at 01:50:40pm
have you contemplated the moulton? smooth ride kit? The turbo build has finally started |
20th Aug, 2011 at 01:54:25pm
With those deep sidewalls you should be fine no matter how hard the shocks are. Are the tyre pressures set to 80psi?
In the 13's at last!.. Just |
20th Aug, 2011 at 01:55:13pm
Where on the car does it rub?? Drives
20th Aug, 2011 at 02:10:46pm
2 options , run it higher on the back and turn the dampers to softest ,thats how i run mine . or tub the arches . im using gaz on softest on the back and no3 on the front for general use ,then 3 on the back and 5 on the front for wapping about . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
20th Aug, 2011 at 05:30:42pm
It's rubbing on the inner arch rather than the top?
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
20th Aug, 2011 at 06:07:16pm
20th Aug, 2011 at 06:27:40pm
I'll bet that call was like those new fosters adverts but in reverse....
20th Aug, 2011 at 07:12:09pm
Al, we need to know where it is rubbing mate. Wheel off and a picture please.
21st Aug, 2011 at 09:31:23pm
Bin the Gaz', fit std dampers. This on 10" is comfy :) On 13th Jul, 2012 Ben H said:
21st Aug, 2011 at 09:34:48pm
sit on a cousin 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
21st Aug, 2011 at 09:56:16pm
Nice typo. |
337 Posts Member #: 9138 Senior Member wolves |
21st Aug, 2011 at 10:01:03pm
not mine
