Home > Help Needed / General Tech Chat > Missing under load ??
jambo
Member #: 1390
Yeovil, Somerset
right problem number two ! the car will rev though fine when not in gear but when you drive it and it goes to come up on boost it starts to miss, will drive fine not on boost ( under 3200 rpm)
any ideas ?
cheers James
I'd definately start by looking at fuel pressure. It sounds like the float bowl is not pressurising. this could be caused by a blockage in the carb.
You could try the T-Piece trick, if this fixes it then you know where to look in the carb, i.e. the pressure feed to the float bowl from the plenum.
If not fuel pressure it could be ignition related, are you using a standard metro turbo dizzy? the modules can fail and give all sorts of wierd symptoms.
tadge44
Member #: 2500
Buckinghamshire
Or weak mixture ?
Or (ny usual response) broken/damaged part throttle lean off pipe.
yes all of the above but if all other items check out OK ........
any! misfires under boost is caused by the mixture too weak................... an AEM lambda gauge is a must in a turbo engine
jambo
Member #: 1390
Yeovil, Somerset
this beginning to really p**s me off now
had a look with a mate today and it ran fine !!!!!!!
should their be a filter before the fuel pump the only one i can see is on the bulkhead ?
cheers jambo
Have you checked all the above?
jambo
Member #: 1390
Yeovil, Somerset
new part throttle lean off pipe.
oh and what is the t piece trick
Yo-Han
Member #: 3228
North of the Netherlands
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2103
Search and find... :)
Dazed and Confused....
jambo
Member #: 1390
Yeovil, Somerset
Cheers yo-han
i did that a couple of days ago, will give it a try over the weekend, some time the car is fine some days it's a real pig ! been fine for 2 or 3 days nows
jambo
Member #: 1390
Yeovil, Somerset
evening chaps
well last nite at bout 7 pm me and some mates thought we would go to combe so we pulled the ERA out and it started to play up 5minutes late we had done the T piece trick and it ran fine all nite and all today ! yeah
I have one question if i may, is it ok to run this long term ?
many thanks jambo
Edited by jambo on 24th Sep, 2011.
YES!
I had a similar issue. Dv was sticking open.
jambo
Member #: 1390
Yeovil, Somerset
cool thats that sorted !
cheers jambo
jambo, what in the end did you sort ? all of tha above or just the DV sticking open ?
dig-mini
Member #: 9269
Rotherham
What is the t-piece trick
Craig
metroturbo
Member #: 989
North Yorkshire
If this is an ERA, have you still got the anti run on valve connected. This can fail to close and cause the problems you describe.
