| Home > General Chat > Full boost? | |||||||
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
25th Aug, 2011 at 07:05:48pm
Only covered 250 miles so far with my new turbo engine, but already planning to change my T25 hybrid turbo. It starts building boost from 2.5k, but doesnt reach full boost (16psi) until 3.8k. Is this normal? Is rises progressivly ie. 4 psi @ 2.8k, 8psi @ 3.2k, 12 psi @ 3.4 until 16psi. It all happens very quickly, and makes the power delivery very smooth and tractable but I expected slightly less lag and I studden surge of boost.
Class C 3rd Place Avon 2011 14.18 @101mph |
25th Aug, 2011 at 07:22:15pm
A lot of people here rave about the drivabilty of the gt17, but is the lag really an issue with the car? Edited by minimole23 on 25th Aug, 2011. On 7th Oct, 2010 5haneJ said:
25th Aug, 2011 at 07:34:23pm
It's not really an issue, I'd just like the turbo to be more efficient and suited to the application. The turbo was the first thing I bought for the project, I wish I'd waited an gone for the gt1752 but I bought a mirage kit and thought I was tied to the T2 range. This is my first turbo mini so I can't compare it to anything expect my mate standard T3, which it's considerable better than. Edited by alaskanow0 on 25th Aug, 2011. Class C 3rd Place Avon 2011 14.18 @101mph |
25th Aug, 2011 at 07:52:20pm
I belive a gt17 will fit straight onto a mirage manifold, you just need to construct a downpipe. Do a search though as I think you need to grind a bit out the back of the block above the fuel pump drain and a couple of other tweeks. On 7th Oct, 2010 5haneJ said:
25th Aug, 2011 at 07:59:12pm
A good general rule of thumb is that if you have full boost at 4k, then the turbo will deliver up to 8k. If you have a turbo that will deliver full boost at 3k, then it will be struggling by 6k.
25th Aug, 2011 at 08:13:57pm
I plan to rolling road my hybrid and standard t2 to compare graphs at same peak boost. luckily I have free access to a rolling road. I will then be able compare this data to whatever Gt turbo I go for and see what the real difference is. I didn't think the gt17 would clear the block on a standard mirage, so was planning on fabricating my own high flow manifolds which may effect results slightly. Class C 3rd Place Avon 2011 14.18 @101mph |
25th Aug, 2011 at 08:20:18pm
Thanks Paul, that sounds like the turbo is about right then? At what rpm is the gt17 at full boost (16psi). Class C 3rd Place Avon 2011 14.18 @101mph |
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
25th Aug, 2011 at 08:25:21pm
If its a help, my gt17 is on a std mirage, some mods to the studs and a 3mm shave of the block, no bulkhead box on mine either, I cant really give an rpm off the top of me head but to me the 17 seems to build boost very quickly. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
25th Aug, 2011 at 08:25:28pm
heres a graph of boost rise ..its in mp but 1000 mp =15psi.
Edited by robert on 25th Aug, 2011. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
im shit Edited by oli79 on 25th Aug, 2011. On 18th Oct, 2013 apbellamy said:
25th Aug, 2011 at 08:40:57pm
Looking at the graph mines boosts up just like the red, green and blue lines. Panic over. Class C 3rd Place Avon 2011 14.18 @101mph |
25th Aug, 2011 at 08:41:29pm
What turbo is each off the cars running? Edited by alaskanow0 on 25th Aug, 2011. Class C 3rd Place Avon 2011 14.18 @101mph |
25th Aug, 2011 at 11:49:26pm
Robert gt 17, mark clbygtt t3, kean t2 t2clby and at that time arron had a t3 starmag Drives
26th Aug, 2011 at 08:23:36am
So why does the T3 appear to boost earlier than the T2 & GT17? (rich mixture granted). It appears to be 400 revs earlier almost everywhere. Is this a bigger displacement 1380? Class C 3rd Place Avon 2011 14.18 @101mph |
857 Posts Member #: 1778 Post Whore Northants |
26th Aug, 2011 at 08:50:43am
It's a 1380 |
26th Aug, 2011 at 09:28:37am
yep makes a big difference. On 28th Aug, 2011 Kean said:
26th Aug, 2011 at 11:05:43am
Mine was not a standard T2 in that graph, it had a larger compressor wheel.
26th Aug, 2011 at 11:59:48am
Kean, was it just the wheel or the housing aswel. I'm thinking of swapping back to just a t25 wheel. Class C 3rd Place Avon 2011 14.18 @101mph |
26th Aug, 2011 at 12:15:13pm
Wheel and housing mate |
26th Aug, 2011 at 12:22:31pm
I've got what was sold to me as a hybrid T2 but I haven't a scooby whats in it. How would I tell?
