| Home > Help Needed / General Tech Chat > meastro block usage for a mini | |||||||
29th Aug, 2011 at 09:02:48pm
hi all,
29th Aug, 2011 at 09:08:28pm
I think its just the rear main cap robert. I'm sure Tadge44 would know. If something is worth doing, it's worth doing half of. |
29th Aug, 2011 at 09:13:13pm
I would image it's the same a converting a Midget block, there's a thread about it somewhere but I'm struggling to find it. Isambard Kingdom Brunel said:
29th Aug, 2011 at 09:16:20pm
On 19th May, 2008 Vegard said:
I've helped convert a Marina block to transverse :) I think you need to have a chat with the Viking Isambard Kingdom Brunel said:
29th Aug, 2011 at 10:40:33pm
Not sure about the Maestro Robert, but the only issue will be, as stated, the rear main cap. If its enclosed and the oil does not need to be contained,like the mini, then even that is not an issue. The crank is likely to be different though as I believe it was coupled to a Golf type gearbox so may not have the taper on the tail for the flywheel.
30th Aug, 2011 at 01:13:32pm
i have if i go and get it ,i have a mini crank ,would that just drop straight in and i ignore the main seal?
30th Aug, 2011 at 01:34:10pm
I was told by a chap that has maestros and various a series engined cars that it will go on without work, but I don't know whether I trust that advise. get it anyway Robert, fit a mini main cap and have them line honed. On 11th Feb, 2015 robert said:
30th Aug, 2011 at 03:50:02pm
Thats the best advice, but expensive.
30th Aug, 2011 at 04:11:18pm
yup i reckon so david , i csn allways flush the cap off with the angle grinder. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
30th Aug, 2011 at 04:13:58pm
says the man with a lathe in his dining room... On 11th Feb, 2015 robert said:
30th Aug, 2011 at 04:14:37pm
bloody good for mixing the gravy! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
30th Aug, 2011 at 05:25:09pm
What about running it with the 5speed box?? Drives
319 Posts Member #: 1742 Senior Member essex |
30th Aug, 2011 at 05:27:48pm
im interested in this as i got an engine kicking around. I saved it for rods head etc but if the block is of use even better. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
30th Aug, 2011 at 06:21:01pm
On 30th Aug, 2011 Paul R said:
What about running it with the 5speed box?? ![]() unfortumately the gravy tends to end up all over the place .2nd gear was ok .:) Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
30th Aug, 2011 at 08:59:30pm
Find another block, leave this for the inline boys. They need them as well. On 13th Jul, 2012 Ben H said:
30th Aug, 2011 at 09:29:17pm
Hear hear say I - thanks V |
