Home > Help Needed / General Tech Chat > fpr mounting
100ev8
Member #: 9138
wolves
does the FPR need to be mounted horizontal (if you know what i mean ) or can it be mounted at any angle ?
is it best to keep the boost ref pipe as short as poss ?
trying to mount mine under the wing to try to keep the engine bay a bit tidy
any one got pics ?
rob
http://www.fishfight.net/
100ev8
Member #: 9138
wolves
anyone ?
Not critical which way up it is, but I would put it where you can get at it for adjusting fuel pressure.
my only other thought would be positioning it so that it or the hoses and pipes are not in the firing line from road debris off the front wheel
mini93
Member #: 2017
Warwick.
got a piccy of mine,
mounted on the teeny tiny lip, fitted with the metal bonnet fine but my FG one i had to thin down, probably be alright with button head bolts though rather than the cap heads i currently use
David.
xxM1n1_MASTAHxxx
Member #: 9584
Turbo Minis :D
think it goes anyway my pressure fuel reg is like above pic tho too...
OO NANA
