| Home > General Chat > straight cut box | |||||||
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
4th Sep, 2011 at 10:37:00pm
what do u guys reckon to a straight cut box and straight cut gears for 300 sheets? Done now needs redoing lol |
4th Sep, 2011 at 10:40:49pm
Depemds on condition, gear set ect any more info? Drives
4th Sep, 2011 at 11:05:56pm
Good price if its in working order. If something is worth doing, it's worth doing half of. |
4th Sep, 2011 at 11:06:46pm
got some pics the guy says he doesnt know much about it, it was fitted to his 1275 while he was at uni done less than 10 tho. Drops look good and chunky. Il put the pic on in the morning Done now needs redoing lol |
4th Sep, 2011 at 11:11:22pm
Don't tell anyone where you are buying from or you may get gazzumped! lol If something is worth doing, it's worth doing half of. |
4th Sep, 2011 at 11:22:35pm
If it's been student owned and probably not had oil changes I'd get close ups of the gears, look for pitting on the teeth. Probably add £150 for basic rebuild bits as it may well need stuff like baulk rings and some bearings plus the right size thrust washers to put it all back together (don't forget you also have to pay carriage to get bits to you once you've measured up for them, unless you have lots of spares). Then you have a good idea where you are at.
5th Sep, 2011 at 09:28:43am
A 2nd hand SC gearbox is rarely worth anything at all. On 13th Jul, 2012 Ben H said:
5th Sep, 2011 at 09:30:27am
I've only ever bough s.c. boxes second hand. all have been fine. On 11th Feb, 2015 robert said:
5th Sep, 2011 at 11:15:45am
you have been lucky andy.
5th Sep, 2011 at 11:26:59am
Mine was secondhand too.
In the 13's at last!.. Just |
5th Sep, 2011 at 01:30:10pm
Stupid Edited by theoneeyedlizard on 5th Sep, 2011. In the 13's at last!.. Just |
5th Sep, 2011 at 01:30:17pm
Phone Edited by theoneeyedlizard on 5th Sep, 2011. In the 13's at last!.. Just |
5th Sep, 2011 at 10:12:57pm
Whats the cheapest you can build one? On 19th Jan, 2010 wil_h said:
6th Sep, 2011 at 06:50:39am
not that cheap with gears and drops Done now needs redoing lol |
6th Sep, 2011 at 07:51:32am
Once you've replaced the primary gear bush, mainshaft and the laygear + shaft, the price would be near indentical.
6th Sep, 2011 at 08:24:00am
On 6th Sep, 2011 Vegard said:
Once you've replaced the primary gear bush, mainshaft and the laygear + shaft, the price would be near indentical. I'd NEVER buy a gearbox without it being in pieces. S/C box in our van was used and owes us less than a new one with all new bearings etc fitted and is spot on. Edited by apbellamy on 6th Sep, 2011. On 11th Feb, 2015 robert said:
