| Home > Help Needed / General Tech Chat > GAZ shocks LOOK | |||||||
![]() 62 Posts Member #: 9439 Advanced Member stoke on trent |
5th Sep, 2011 at 12:05:24am
Hey, thought id let you guys know, I sent my rear coilovers off to GAZ to be serviced. All went fine, got them back and they supplied new top bushes, the ones that sandwich the wheelarch. So I stuck them on the car, tightened the top nuts up to compress the bushes a little then went for a drive, all seemed ok. After covering a further 100 odd mile a knocking developed at the back. So on investigation, the lower of the two bushes had squashed to almost nothing, which 1. Loosened the whole assembly and 2. Lowered the rear a half inch, which I think youll agree is not to safe, especially when the rears running low anyway. So I guess, watch out for these shit quality bushes, they feel much softer than the ones I took off, and have a cylindrical appearance rather than a rounded one, heres a few pics…
5th Sep, 2011 at 09:37:12am
What do you expect when resting the entire Mini's weight on a couple of rubber bushes? On 13th Jul, 2012 Ben H said:
5th Sep, 2011 at 10:22:32am
The ones on the left looks like I'd expect after tightening, the ones on the right looks like new.
Edited by wil_h on 5th Sep, 2011. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
5th Sep, 2011 at 03:16:53pm
The one on the right has done at least 5000 miles, the left one has done less than 100, no problem?...the bush is allowing the washer to pull through it. Edited by zerocool_jj2000 on 5th Sep, 2011. |
5th Sep, 2011 at 03:35:30pm
Have you actually contacted GAZ direct about this and given them chance to investigate/rectify your problem?
5th Sep, 2011 at 03:55:11pm
I wasnt bad mouthing GAZ simply explaining what had happened, and that it was something to watch out for. ive not contacted GAZ yet, i only sorted it lastnight, i will be shortly. An yeah tbh from dealing with them on the phone reguarding the servicing they did seem helpful, we'll see. Edited by zerocool_jj2000 on 5th Sep, 2011. |
