Home > Help Needed / General Tech Chat > straight cut idler bearing clearance
almichie
Member #: 2065
right then, Richard has been helping me with my straight cut box assembly and idler tolerance (read built it for me). He has told me its .001" over tolerance or 0.008". Ive checked with somerford and the 0.136-0.137" shims are £45! how important is it with the sc drops for the tolerance to be bang on??
Has anyone got any shims they dont need????!
Shaft seems nice and snug
I like to keep em tight when I build them.
Shouldn't matter "too" much with the SC gear but would you be happy with the gear slapping about???
jamie@thefatgarage
Member #: 9345
Sheffield
http://www.minispares.com/Product.aspx?pid=38019
Bit less than £45...
almichie
Member #: 2065
Thanks, Richard has come to the rescue (again!) he found some idler shims in his car!! and they bring it down to 0.006" tolernce which is where we want it. panic over! Thanks for the good advice as always
Have you got an original Rover gasket there? You could try onw of those. Also, make sure that the gasket mating surfaces are CLEAN. I always use an air tool like this
http://www.marmax.co.uk/acatalog/301_eu_90...er_6mm_main.jpg
to get ALL the crap away and possibly a little aluminium. This means that all the studs from the casing must go, but I take it that you've done this anyway.
If you grind the mating surfaces with this, I'm sure that you'll get within tolerances. I personally think that 008 is too much. I'd never build something with more than 004. Never.
Do you use a torque wrench when fastening the flywheel housing before measuring?
almichie
Member #: 2065
Hmmmm. Thanks vegard. It's not an original, no. I'll flat off the faces see if it's better
Mr Joshua
Member #: 1954
Luton Bedfordshire
When I got my set I was told to shim them to 0.001" I was told 0.008 was way too loose
Own the day
