Home > General Chat > 4 Pinion diff........minispares copy
Kean
Member #: 341
aka T2clubby
South Staffs
Just got my new diff, bud666 was having trouble getting one from anywhere, then he found 2 at Moss...so we grabbed them sharpish.
Apperently its a copy of the minispares one, and has the off set pins. It seems to be of great quality and fitted together easy.
So next time you need one try moss, cos it looks like noone else will have any for a while
Pic here.......
Edited by Kean on 10th Apr, 2005.
dan
Member #: 93
i thought moss used minispares stuff anyway,
i'm sure the part numbers were the same at some point in the not too distant past
Kean
Member #: 341
aka T2clubby
South Staffs
Yeh your prob right mate, I doubt that there are that many companies making these anyway
it doesn't look excatly the same as minispares, but I'm sure it'll do the job
It does indeed not look like the Minispares one, as the MSC one only has ONE locking stud for the four pins, whereas this one has got three. The MSC locking bolt/pin is threaded as well.
This is the minispares one
