| Home > Help Needed / General Tech Chat > New Hi Lo\'s and yellow spot rubber cones? Riding monty high? | |||||||
150 Posts Member #: 8909 Advanced Member North Cornwall |
8th Sep, 2011 at 04:11:14pm
Hello all
If in doubt... flat out! The words of a true legend |
8th Sep, 2011 at 04:29:12pm
This is common with the yellow dot springs. The easiest fix is to cut down the hi-lo. Depends how much it needs to come down http://www.twin-turbo.co.uk
8th Sep, 2011 at 04:52:32pm
Sure they don't take a little while to settle? my standard cones took ages to settle, then had to keep winding them up. On 7th Oct, 2010 5haneJ said:
8th Sep, 2011 at 05:16:40pm
yup, get some miles on it first. give it a couple of weeks and see how much its settled by. On 20th Oct, 2015 Tom Fenton said:
8th Sep, 2011 at 06:12:49pm
I have had to modify my hi-los when fitting both red and yellow dot cones.
8th Sep, 2011 at 06:34:12pm
From Minispares site:
8th Sep, 2011 at 07:44:47pm
^^^ On 26th Oct, 2004 TurboDave16v said:
9th Sep, 2011 at 12:32:27am
this is my effort, i took a little more off than that in the end
Yes i moved to the darkside |
9th Sep, 2011 at 10:44:05am
9th Sep, 2011 at 10:48:12am
Ouch! If something is worth doing, it's worth doing half of. |
9th Sep, 2011 at 07:52:07pm
Thanks for the replies peeps.
9th Sep, 2011 at 10:38:34pm
On 9th Sep, 2011 Sprocket said:
Yes, but those are not HiLo's are they ![]() strictly speaking..er no there minispares adjust a rides or something but they do make it higher or lower
9th Sep, 2011 at 11:44:54pm
Techically 'Adjust A Ride' is a Minisport trade mark, and those aren't Adjust A Ride's. 'HiLo' is a Minispares trade mark (Originally Ripspeed), and those aren't HiLo's either.
10th Sep, 2011 at 11:31:59pm
11th Sep, 2011 at 01:34:00pm
so would the minispares hilos need machining as much as that? My build thread..
11th Sep, 2011 at 01:47:38pm
yes |
11th Sep, 2011 at 04:09:02pm
bugger!! i take it this applies to the red dot's as well. looks like im going have to take my suspension apart again! lol My build thread..
11th Sep, 2011 at 06:35:33pm
Yes, red and yellow dot are the same size. http://www.twin-turbo.co.uk
16th Sep, 2011 at 09:58:24am
Since I was on here last I took the rubber cones to be machined, had 8mm taken off the fronts, it's come down abit more but still needs to come down another 2-3 inches. Somewhere I need to take off another 8mm, may look at getting the knuckle machined and the hi-lo. If in doubt... flat out! The words of a true legend |
16th Sep, 2011 at 10:04:27am
What exactly have you had machined?
16th Sep, 2011 at 12:28:47pm
Removing rubber in the cone helps none. The threaded bolt will still touch the cone inside if not shortened.
16th Sep, 2011 at 01:29:25pm
I've machined the part of the cone that locates then the subframe.
16th Sep, 2011 at 01:29:27pm
16th Sep, 2011 at 09:50:27pm
Minispares suggest you machine the hilo not the spring
