| Home > Show Us Yours! > Sundays Progress | |||||||
10th Apr, 2005 at 07:48:31pm
Spent this afternoon down the workshop. I manged to mount my oil temp and oil pressure sensors, I've been putting this of for ages. Team www.sheepspeed.com Racing
10th Apr, 2005 at 07:55:39pm
not tempted to just run a leccy fan and ditch the pump housing all together? thats my plan but then might run a front mounted rad somewhere!
10th Apr, 2005 at 07:59:47pm
I think I need to weld a new T peice which directs water in the correct way, maybe more of a Y than a T, do you think that would help? how would you do it? Team www.sheepspeed.com Racing
10th Apr, 2005 at 08:03:10pm
reckon id do heater take-off to turbo to extra rad then back in the top hose...
10th Apr, 2005 at 10:05:20pm
if I do it your way iain, I'll be taking hot water from top of engine, and putting it through turbo to get even hotter, would it not be better to take it from bottom hose through turbo, and then connect turbo outlet, and heater take off, through a auxilary rad then back into main rad Team www.sheepspeed.com Racing
11th Apr, 2005 at 07:21:00am
Hmm, not too sure, possibly from the head, through the aux rad, through the turbo then in the top hose to cool down again?
11th Apr, 2005 at 08:11:12am
Looks great. Don't use an old oil coooler as a water rad. It's very inefficient when used with water, as it-s designet for different flow and viscosity. Honest :)
969 Posts Member #: 47 Post Whore Not very sunny swanage |
11th Apr, 2005 at 10:25:27am
maybe use a heater matrix instead? And on the 7th day........... God created turbochargers! |
11th Apr, 2005 at 12:21:13pm
honda cbr 600 rad is same size as 13 row and has a fan. why not move the oil filter at the same time ? Edited by Dangerous on 11th Apr, 2005.
11th Apr, 2005 at 12:50:16pm
neat jimster the oil temp sender one before the oil cooler and one after
11th Apr, 2005 at 01:09:56pm
Jim what i/c is that you are using?
11th Apr, 2005 at 01:13:03pm
TD5, same as the one i've got sat at home waiting to squeeze in |
11th Apr, 2005 at 02:56:29pm
Ben - I think that's a oil pressure switch / pressure gauge sender, not an oil temp... On 17th Nov, 2014 Tom Fenton said:
11th Apr, 2005 at 05:18:07pm
Ian and dave are right, it's a TD5 intercooler.
12th Apr, 2005 at 11:31:48am
sorry my mistake
12th Apr, 2005 at 12:00:33pm
I was looking at this, a good place to tap in into the gearbox would be in the endplate which the spedo housing goes into, as you could take this off with engine in place (although it would be bloody awkward) drill, tap, fit sensor, then refit to gearbox Team www.sheepspeed.com Racing
12th Apr, 2005 at 02:09:03pm
Yes that is where I am planning to fit one, more because I don't want to risk knackering the entire g/b case, the end case is easier to come by!
12th Apr, 2005 at 07:30:34pm
cheers jimster, tom
