| Home > Wanted > Top arms without bearings! | |||||||
275 Posts Member #: 4600 Senior Member Melton Mowbray, <BR>near Leicester |
11th Sep, 2011 at 06:07:16pm
Maybe a long shot but I need a pair of top arms without the bearings in.
11th Sep, 2011 at 06:32:35pm
I think I have some top arms, but with bearings in. Why do you want them with no bearings? They are easy enough to get out. http://www.twin-turbo.co.uk
11th Sep, 2011 at 10:10:22pm
Any tricks for getting them out? I've tried everything I can think of! even tried welding a nut to the bearings so I can pull/knock them out, doesn't work! |
11th Sep, 2011 at 10:12:11pm
smash the rollers out then grind through the walls, then pull them out with pliers. On 28th Aug, 2011 Kean said:
11th Sep, 2011 at 10:16:54pm
Ah the destructive method, I'll try that! Cutting disc on a dremel should do the trick. |
11th Sep, 2011 at 10:49:29pm
My rollers smashed themselves out for me.
In the 13's at last!.. Just |
