Home > Help Needed / General Tech Chat > Timing cover vent/non vent
Dangerous
Member #: 417
I know it is meant to be vented but would a non vented one be ok*oh well*
maybe - but more breathers the better.
Why not mod it?
All i do is (after removing it) take a hacksaw down the side of the breatherpipe, and all the way through the can.
Then cut a thin piece of rectangular sheet metal to the correct size. Next, buy two of those stainless pan scrubs from wilko's for a quid - or less if you shop around (to replace the rusting mess that fell out). Stuff the scrub in the can, then weld the steel plate over the top!
Bosh!
No more fan spacers needed (and easy radiator removal from then on)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Not got one = I run a belt.
Alex
AlexF
not going to run a side rad so no need for me, but if i was i would run one, then pipe it to the rocker cover and have that piped to a catch tank. much neater
Point taken - but why not use the breather can/flame trap to actually stop the majority of the oil mist actually getting upto the catch tank?
You won't be saying 'much neater' when you have a nice film of oil over your engine bay after ragging it round combe for 20 laps! LOL!
Edited by turbodave16v on 11th Apr, 2005.
Aka jim last year! (cant actually remember where all his oil came from though!)
Oh yeah, didnt mean get rid of the trap, just meant route it to the rocker, more chance to remove extra vapour then *smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Main the exhaust if I remember :p
alex
AlexF
pardon?
no oil was coming from my turbo, it was all breathers! mainly the breather near the rad as I forgot to put a pipe on it, so the fan was sucking all the air from the breather, and blowing it around the engine bay. The other breather on the flywheel housing had no pipe on it either, it's still doesn't actually, another job for me
Dangerous
Member #: 417
What I meant was I have a cover of a 998 with no vent can I use this or find a 1275 vented one
better to find one with a vent
ive got loads i reckon....
aaahh - so you don't have even a basic 1275 one...
No reason why you couldn't mod a 998 one to put a breatherpipe on there... As you have to mod the 1275 one to clear the fan anyway, i'd just stick a pipe on a 998 one.
