| Home > Help Needed / General Tech Chat > Smoke | |||||||
166 Posts Member #: 221 Advanced Member |
11th Apr, 2005 at 11:59:46am
I have the 2 engine breathers attached to 2 K&N type mini filters. The one next to the radiator seems to blow a lot of smoke. |
11th Apr, 2005 at 12:04:26pm
if put into the inlet then it will lower the octane of the fuel.
11th Apr, 2005 at 12:08:34pm
If i take the filter off and rev it the smoke is bad? Engine has only done 100 miles or so since rebuild.
11th Apr, 2005 at 12:41:56pm
leave it to bed in then. rings wont have had chance to run in properly yet id say. should clear up once you get some miles on it.
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
11th Apr, 2005 at 01:19:37pm
Whats it like if you rev it with the oil filler cap of if its breathing heavy through there it sounds like rings |
11th Apr, 2005 at 01:25:31pm
Rebuild as in???
11th Apr, 2005 at 01:27:23pm
This has been discussed quite a few times now.
11th Apr, 2005 at 03:15:39pm
Rebuild as in everything replaced. |
11th Apr, 2005 at 03:26:58pm
11th Apr, 2005 at 05:08:12pm
yes mate, all of the above. Everything is nearly new. |
11th Apr, 2005 at 05:13:33pm
compression test to check everything is even would be might first port of call |
