Home > Help Needed / General Tech Chat > megajolt standard metro turbo map? where do i get it from?
welshdan
Member #: 1111
s wales
hi and good evening,
im a bit new to megajolt so please bear with me. i have installed the components and started to wire it up. i need a map to get the car to my local rolling road for setup. i the engine is a slightly different spec to the mg metro turbo - i have intercooled it, ported larger valve head, sw5 cam. really its a slightly spiced up standard ish spec engine.
i have briefly searched the forum and the net including autolabs for a standard metro turbo map, but have not been able to find one.
does anyone have any pointers?
many thanks
dan
jdisel
Member #: 9515
ireland
Dont know much about megajolt maps but i think this link has a basic turbo map attached.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=128121
A job worth doing is a job worth over doing
dude its all here... and on there....
an old trick before ms/ mjlj was just to run static timing something else to consider?
Yo-Han
Member #: 3228
North of the Netherlands
I think this is what you need: (following the link by jdisel)
http://www.jamesfawcett.co.uk/cms/index.ph...&gid=3&Itemid=3
5th and 6th from above
Dazed and Confused....
bennyy
Member #: 9037
Doncaster, yorkshire
There is an a series nap that cones on the disc with Megajolt, john has a good turbo map that a lot of us use.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Feel free to use it. However I take no responisibility if you blow up your motor if it isn't suitable.
Edited by John on 19th Sep, 2011.
sim_ou_nao
Member #: 114
Porto/Portugal
Where can we get the "john" map?
Pedro Silva
Don't have the map file to hand but this is pretty much it. We have 2-3 degrees more advance in the 180kpa+, 3000rpm+ area though now.
sim_ou_nao
Member #: 114
Porto/Portugal
Thank you Jonh :)
Pedro Silva
wng691s clubby
Member #: 9252
Cleethorpes
sorry to drag up an old thread but i was wonding what spec engine johns mas was for just trying to see if its suitable for mine
Done now needs redoing lol
standard block, turbo pistons, phase 2 cam, well ported head 36/30 valves, GT17, loads of boost.
wng691s clubby
Member #: 9252
Cleethorpes
cheers andy not that good for me then
Why not? It's based on RPM and load so will still work for other engines.
You are still going to make boost and see similar RPMs...
wng691s clubby
Member #: 9252
Cleethorpes
hmm thought using different turbos may make a differance
Boost is boost. That map would work with a supercharger.
wng691s clubby
Member #: 9252
Cleethorpes
il use it as a base and can get it tweaked at the rolling road. Cheers andy for clearing that up
nala56
Member #: 9661
Sheffield South Yorkshire GB.
I have megajolt maps, from the disk from trigger wheels, your welcome to them, but how can i get them to you.. Alan
Main Build
Upgrade to Turbo
nala56
Member #: 9661
The whole contents from the disk is about 42 meg
Main Build
Upgrade to Turbo
wng691s clubby
Member #: 9252
Cleethorpes
urm would they email not sure what the size limit is on emails. My email is randerson_c@hotmail.com. It myt work
nala56
Member #: 9661
OK mate, just the maps, sent them already.. Alan
Main Build
Upgrade to Turbo
nala56
Member #: 9661
Hope your not at work now. lol
Main Build
Upgrade to Turbo
nala56
Member #: 9661
Have you got- Version 4.0.2 Configurator
Main Build
Upgrade to Turbo
wng691s clubby
Member #: 9252
Cleethorpes
no i dont think i have im not sure lol new to all the megajolt stuff, thanks for the maps
Edited by wng691s clubby on 24th Dec, 2011.
nala56
Member #: 9661
You will need this software to put on your computer, then will need a lead to connect the comp- to the megajolt to install the map, will send you the software.. Alan
Main Build
Upgrade to Turbo
wng691s clubby
Member #: 9252
Cleethorpes
ah yes have software and lead thanks loadz tho
