| Home > Technical Chat > Power for a given boost on k1100 heads | |||||||
20th Sep, 2011 at 07:05:08pm
I have been attempting to try to find out what sort of power k1100 Turbo minis are producing for a given boost in order to help decide what the best turbo option for my car will be.
20th Sep, 2011 at 07:20:30pm
It seems alot of people are opting for the gr2056 now and maybe one or two for the? gt22, as paul s said the gt 17 wouldnt give enough power for his application but otheres have seen 200+ Drives
20th Sep, 2011 at 08:18:15pm
What I thought I said was that although some have seen over 200hp from the Gt17, if your target is over 200hp, then there are better turbos such as the Gt2056 or the TD04-13t.
Edited by Paul S on 20th Sep, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Sep, 2011 at 08:20:49pm
Right after a search of various threads I have found this, so here is some useful info from turbo harry about his hybrid gt2056.
On 27th Mar, 2010 TurboHarry said:
I was on an old Bosch dyno to optimize ignition....it made 225hp at the crank at 1 bar boost at 7800rpm (LT inlet, RS exhaust cam), the max I ran on the street was 1,2 bar. The compressor map of the GT 2056 is very broad and effective - I took the CHRA and turbine from a Mercedes (V-band) and fitted the bigger 56 compressor from another turbo....IIRR it was from an Alfa, but no sure anymore? If I could join the RR sessions in England easily I would run for sure more boost... )
http://www.minifreunde.at/harry/links/turbo.htm Based on these numbers using a gt2056 I don't think I'd be far off 200bhp with a gt17 at 14psi. On 7th Oct, 2010 5haneJ said:
1425 Posts Member #: 690 Post Whore Norfolk |
20th Sep, 2011 at 10:00:05pm
305hp at 8k, 22psi Gt28 based, engine dyno proven not predicted
If Carling made Mini engines
21st Sep, 2011 at 01:03:26am
Its all down to what you want from the engine in the first instance.
Edited by Sprocket on 21st Sep, 2011. On 26th Oct, 2004 TurboDave16v said:
21st Sep, 2011 at 07:52:23am
Good stuff sprocket, your engine spec is more or less exactly what I was planning even with the same compression ratio. You will just have to get it finished and get some numbers for it as that will confirm whether the gt17 will supply the air required.
21st Sep, 2011 at 09:20:04am
hi moley ,
21st Sep, 2011 at 11:43:56am
I'd be more tempted to compare the GT1752 with a GT2052 50 trim, since it uses a simiar wheel. The only real difference then is the A/R and the smaller turbine which should see it boost earier than the GT20? On 26th Oct, 2004 TurboDave16v said:
