Home > Help Needed / General Tech Chat > tappet settings for 1.3:1 rollers
Nick
Member #: 154
Midlands
as title really, anyone know what they should be? used to run 14thou across all 8 on my non roller rockers. running a ph2 cam up to 7.5k rpm if it makes any odds.
Pretty sure it's 14 thou exhausts and 12 thou inlets as per standard.
Isn't it the cam that dictates the gap?
Cant see any reason why it would change over the standard rockers dude.
Pauly
Member #: 9045
Wolverhampton, West Midlands
Run 15 thou across mine dude. They usually say in destructions what to set them to, did with mine anyway.
Be over in a bit anyway
The clearance does alter with rockers purely because as the valve and pushrod grow with heat, the increased ratio of the rocker exaggerates this if you have say 1.5 rockers compared to 1.25-ish of the standard ones.
Nick you are still using 1.3's so you should be able to keep them more or less the same, the alloy rocker will expand a touch more with heat, so an extra 2 thou over what you usually use will not hurt.
Edited by Tom Fenton on 21st Sep, 2011.
Nick
Member #: 154
Midlands
cheers Tom :)
