Home > Help Needed / General Tech Chat > Fire gum should I ??
Right lads, how many of you lads use FireGum on your outlet manifolds. I have been putting it on the gasket but it makes a right mess of the head.
It will have a gen mpi/spi gasket on it.
Thanks simon.
i put some sealant on my clubby but to be honest wish i didn't. seems to seal just fine without
I have always done it, as it would not seal and would piss out fuel on boost.
jamie@thefatgarage
Member #: 9345
Sheffield
Although they have only had limited running so far I have 2 turbo A-Series cars that are fine without anything but a gasket.
Mine never leaks and I've never used any sealant.
ive never used sealant bar on the manifold to downpipe join that usually gets a very light smear
I use sealant on the turbo to manifold flange, but not head to manifold.
Also the only manifold gasket that has ever lasted any length of time for me is the turbo one wit hthe fire rings on the exhausts. Is the Mpi one like this?
tadge44
Member #: 2500
Buckinghamshire
Like wil, I use firegum on the turbo, both to the manifold and, if appropriate, the elbow to manifold.
Decent manifold to head gaskets and new studs/nuts and there should be no problem.
If it pisses out fuel on boost it sounds like the inlet manifold isn't being clamped tight enough against the gasket.
There seems to be a wide variation in the thicknesses of both exhaust and inlet manifold flanges and if they aren't both identical, one or the other won't seal. I made some stepped washers rather than use sealant.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Simon.
I just use Blue Hylomar on the inlet and outlet faces of the head and manifolds with my SPi/Mpi gasket.
Never had an issue.
Only use fire gum on the exhaust downpipe and clamp.
Rich.
I use the mpi style gasket and no sealant. but then not much boost compaired to you guys.
scott the joiner
Member #: 9229
newcastle upon tyne
I use an injection gasket no sealant & no problems run 13 psi boost
