Home > Show Us Yours! > soon to be turbo
arron81
Member #: 9561
Purbrook
thought id show a few pics of my mini just after it was done about a year ago before it becomes a turbo. there a couple of things different now like carbon bonnet full cage done in white black tinted windows. also got a set of carbon miglia arches to go on when bigger wheels are bought. let me know wat u think
Edited by arron81 on 28th Sep, 2011.
arron81
Member #: 9561
Purbrook
sorry for some reason its not showing my pics
arron81
Member #: 9561
Purbrook
ok cant work out y it wont ket me do it any help please do i need to do it through photobucket or similar
arron81
Member #: 9561
Purbrook
finally got it ill post one of before aswell
arron81
Member #: 9561
Purbrook
thats a bit of a transformation - nice looking car
arron81
Member #: 9561
Purbrook
thanks
Yep, I like that. deffo needs a turbo.
Looks good. What are your plans for the engine?
arron81
Member #: 9561
Purbrook
ive bought an engine off a guy on here 1330 T3 spec is as follows
‎1330cc 5 port turbo engine.
Vmax scart race cylinder head with 29cc chambers to lower the compression ratio.
Forged Omega pistons giving a compression ratio of 7.5:1
Lightened and balanced rods
Cross-drilled, balanced and hardened crank
Adjustable Vernier Duplex chain.
Kent MD 286 cam
double grey diaphram.
Electronic distributor with maximum advance restricted to 24 degrees
Straight cut clubman gears,
1:1 straight-cut drops,
Salsbury LSD differential,
3.4:1 crownwheel and pinions
MR2 aftermarket intercooler
Metro T3 turbo
buying the gearbox of the same guy at the end of the week
A 286 is not suitable for a turbo install.
arron81
Member #: 9561
Purbrook
The engine before was a supercharged one
wng691s clubby
Member #: 9252
Cleethorpes
nice looking car just wondered what arches they are nice and subtle
Done now needs redoing lol
arron81
Member #: 9561
Purbrook
Think they were group five can't remember but got miglia ones but don't want to put them on until I get bigger wheels
Kean
Member #: 341
aka T2clubby
South Staffs
As Wil stated, the 286 is not suitable for a turbocharged engine, super charging and turbo charging have very different characteristics with regards to cams.
arron81
Member #: 9561
Purbrook
Ok I'm guessing the 266 is the one then how easy are they to dial in with vernier duplex timing gear
yep the 266 is a good bet, the avonbar ph2 is also very good, and the RE13T is worth a look.
you'll need a dial gauge to set the cam up, and a protractor (search for the printable TM one) the main thing you need is patience,
arron81
Member #: 9561
Purbrook
Ok I'll look into that then thanks for letting me no before I put the engine in. I finished of the bulkhead today and painted it ready for the engine im gettin quite excited
madonminis
Member #: 9371
East Yorkshire
love the plastic grill straight to the valance, nice touch
