Home > Help Needed / General Tech Chat > Belt drives.........
Kean
Member #: 341
aka T2clubby
South Staffs
Shall I use a belt drive setup guys, I've been offered one but cant decide wether to have it or not.
has anyone ever had one break?
And does it need to be adjustable or can can you adjust it enough by moving the teeth?
any advice muchly aprreciatted
if it's not adjustable then you need to use ofset woodruff keys to adjust, just like a chain.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Some are adjustable...
http://www.minispares.com/Product.aspx?pid=35510
Most are like Jim says... I've got that type.
The benifits are more power and much quiter with less stretch issues... Downside is they are very short so need replacing regulrly!
Alex
AlexF
minimark
Member #: 19
newcastle
how more power????
Kean
Member #: 341
aka T2clubby
South Staffs
How regularly?
From what I have read in the past, people claim more power due to "more consistent cam timing with less variation due to chain tension".
Personally I think you would be very hard pushed to prove this. The only other thing I can think of it less resistance driving the belt than a chain? Again, so little difference I doubt you could measure it.
I personally am using the Kent silent chain type vernier setup, used it on a few engines before now and can't fault it.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
You can measure the frictional losses!
Its only a bhp or 3 but its still there... I spent a long time at Ford looking at Friction and studying the causes.
Alex
AlexF
Run a belt for a few years now. I have replaced the belt yearly, but they always look like new when removed anyway.
Phil. *smiley*
Alex
Anything you weren't involved with whilst at Ford?
If you were that involved and studied the causes that much, you can give us a greater explanation can't you?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I could do...
but you lot are only waiting in the wings to shoot down what I say...
I was involved in alot at Ford yes... the department I worked in was basically R&D.
Wasn't involved in lots of things at ford :p
Alex - spitting the dummy!
AlexF
Nicky
Member #: 333
Tadley, Hampshire
I have found the belt drive kits from Minispares to be very good. It is cheap and easy to change a cam belt even with the engine in situ.
As far as power loss goes i feel with one very large oil seal around the cam pulley causing slight fricton power loss could be more than a normal duplex setup.
With the vernier facility you get get the timing spot on and is relatively easy to change to the desired.
"Alex - spitting the dummy"
That sounds like something Michael Jackson partakes in...
minimark
Member #: 19
newcastle
michael jackson`s is in the $hit anyway , cos he swore on the pope`s life he never touched them kids.....
Edited by iain on 12th Apr, 2005.
ha ha ha ha ha ha!!!
giallofly
Member #: 164
The Stig..
Newport Pagnell
*surprised*THREAD HI JACK!!!*surprised*
Good points Nicky, as far as the noise issue goes it is unnoticable as most of us run tuned cars with big cams and clattery drops anyway.
Adjusting a tooth at a time is far to much, worth getting a vernier set up.
JF.
well a belt is slightley..................... less noisey
supposes if you are building the ultimate engine and
"MONEY" is not an issue !!!
ever little helps *wink*
having said that chaps it would also eliminate that hidiouse OIL leak every one comes across from the btm of the chain cover,
SOME TIMES!
iam sure ever ones had an engine with one ?? LOL
i have wrestles with some units over the years
thinking i have fitted the gasket right, only to be gutted when it started to weep after a few months use....................*oh well*
Agree with that Ben! It's the one part I use plenty of gasket goop - but it still leaked!
Next time you do one - out of interests sake - fit the cover, then go and measure the distance from the crank (where the pulley is located) to the outside of the area where the oil seal sits.
I eventually figured out on mine why the oil seals used to wear out and weep like mad after a very short time last time i rebuilt my engine!
Yep, the oil-seal location was offset from the crank centreline by 1.6mm!
Wriggling the cover got it to just under 1mm, but a few of the holes had to be filed out before it was pretty much concentric. Admittedly, only did around 13/1400 miles last year, but ther was no leaks from here for the first time since ever.
Sounds like something JF would say! *happy*:cool:
Doodmeister
Member #: 149
Alberta, Canada
Is there anything you haven’t figured out yet Dave *wink*
I’ve ran belts for around 15 or so years and never had an issue but I would say change it every chance you get, I've never seen any bad wear on the ones removed though.
And I’m sure if they can measure the distance to planets we've never visited then the HP loss/gain from running a belt over chain shouldn't be beyond the capability of man.
How about if you took the belt drive and mounted it on a motoring rig with frictionless ceramic bearings and measured the amount of reactive torque from the motor when running the belt or chain at a given RPM, this would calculate out to friction HP in my book and has in the past on engine motoring rigs. This method also comes in handy for measuring the engines pumping losses at different throttle angles and peak motoring cylinder pressures.
Just a thought.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Karl...
Would you believe it thats exactly what "the rig shop" does in Ford's Dunton Research & Development Centre in Essex....?
Alex
AlexF
Women
EFI A-Series
Americans
How to do what I should be doing at work at the moment.
There are others, but that'll do for the moment
minimark
Member #: 19
newcastle
:cool:
Edited by minimark on 13th Apr, 2005.
another - Why do some women have massive norks, and others like a penny on a paving slab?
Despite extensive research in assorted 'periodicals' and visual aids such as a television or computer monitor, i'm still no closer to understanding it. I will continue my quest however.
Edited by turbodave16v on 13th Apr, 2005.
Doodmeister
Member #: 149
Alberta, Canada
LMAO...
Women = You never will
EFI A-Series = Direct Injection
Americans = Don't bother
Jimster = Who? :)
OK OK, of course in THEORY you could measure the difference. But what I was getting at was adding the belt drive kit to an engine, how would you then be able to measure any power increase? And be able to attribute it to the friction difference rather than slightly different timing, or fuel, or air pressure, or inaccuracies in the dyno you use etc etc........
