| Home > Help Needed / General Tech Chat > Dog box question - Involute Vs. Face Dog...... | |||||||
![]() 99 Posts Member #: 9550 Advanced Member Cornwall, UK. |
28th Sep, 2011 at 06:04:34pm
Hi guys, just quick question in relation to dog boxes - i'm currently rebuilding my hillclimber & looking into going from s/cut synchro to a dog box. Which of the dog boxes is most suitable for a) ease of use & b) longevity between rebuilds - face type dog engagement (swifty/med etc..) or Involute boxes (JKD's)....?
For every action there is an equal and opposite criticism. |
28th Sep, 2011 at 06:15:28pm
Involute refers to the profile of the actual gear tooth if I am thinking straight.
28th Sep, 2011 at 06:33:33pm
Ahh with you, i was along the lines that the involute bit referred to the multiple engaging teeth on the dog gears.? For every action there is an equal and opposite criticism. |
28th Sep, 2011 at 06:37:50pm
I don't think it does. Involute is the form of the gear teeth as they mesh.
28th Sep, 2011 at 06:44:06pm
With you. I wonder if the different dog setup on the jack knights has different terms too.? That's the bit I'm interested in, the actual engaging part of the dog teeth in respect of wear and gear change. For every action there is an equal and opposite criticism. |
1391 Posts Member #: 1686 Post Whore Oxford |
28th Sep, 2011 at 08:57:04pm
What Tom says is correct. In essence its a continually rolling contact point of the gear.
OMG Robert that's a big one |
28th Sep, 2011 at 09:06:42pm
28th Sep, 2011 at 09:11:28pm
Thanks guys, brill animation Joe. That's a good bit of info. So yep it's just the dog engagement I'm trying to find out about, any comments about driving the jk boxes compared to swift or med dog..... And how well they both fair over time, on the dog teeth...
28th Sep, 2011 at 09:16:53pm
I think you the real question you have to ask is how easy/ difficult it is to get spares for the JKD box these days.
28th Sep, 2011 at 09:33:19pm
Fair comment, i see how rare the jkd's are, let alone any bits. I've chance to look at both and just want to assess which will give better life (due to the dog engagement being so different in design) and ease of operation. For every action there is an equal and opposite criticism. |
28th Sep, 2011 at 09:36:04pm
I think you'll find that all SC boxes are involute, and jus t calling thenm involute was jsut a marketing ploy by JK,
![]() 62 Posts Member #: 9439 Advanced Member stoke on trent |
28th Sep, 2011 at 09:41:06pm
28th Sep, 2011 at 09:42:36pm
On 28th Sep, 2011 Joe C said:
I think you'll find that all SC boxes are involute, and jus t calling thenm involute was jsut a marketing ploy by JK, Posted while i was posting
28th Sep, 2011 at 09:53:58pm
Yep thanks guys I think as you say a marketing ploy by jkd makes sense. So just any opinions would be a help as to longevity and driveability of both. Any of you guys driven both jk and face type boxes.? For every action there is an equal and opposite criticism. |
28th Sep, 2011 at 09:54:06pm
I think Joe is right, JKD just used the term 'Involute' more as a marketing angle to highlight the fact their gears were of a superior tooth geometry compared to early straight cut boxes which used simple tooth profiles, being easier to manufacture, but at the cost of durability and excess gear noise. The involute profile reduced both noise and wear rate.
28th Sep, 2011 at 10:00:01pm
On 28th Sep, 2011 nikh667 said:
Yep thanks guys I think as you say a marketing ploy by jkd makes sense. So just any opinions would be a help as to longevity and driveability of both. Any of you guys driven both jk and face type boxes.? A dog box whether JKD, Swiftune, MED or Minispares, are all face dog engagement and work on the same principle, they just look different. What other type of dog engagement is there? On 26th Oct, 2004 TurboDave16v said:
28th Sep, 2011 at 10:20:27pm
Sure thing, the involute gearing makes perfect sense. What I'm angling at is any real world difference in driving or strength of either unit.?
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
28th Sep, 2011 at 10:25:32pm
what sort of power are you planning on running to warrant the dog box? one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
28th Sep, 2011 at 10:32:07pm
Approx 140ish, hillclimb and sprint use. For every action there is an equal and opposite criticism. |
28th Sep, 2011 at 10:32:59pm
Yep thanks guys I think as you say a marketing ploy by jkd makes sense. So just any opinions would be a help as to longevity and driveability of both. Any of you guys driven both jk and face type boxes.? A dog box whether JKD, Swiftune, MED or Minispares, are all face dog engagement and work on the same principle, they just look different. What other type of dog engagement is there? jkd bog boxes ar enot face dogs Colin, the dogs are in the same place as a syncro box , just bigger and slightly less of them,[there appears to be no detent springs in the seelecter hubs] so there is obviously an underscut on both parties. if you miss a gear in the Don you are in bother as its a painfull experience trying to select a cog once the corresponding two sets of dogs have a significantly missmatched speed, anmd a sthere are lots of them its dificult to slot in place ERGO RULE NO 1, learn to change gear 1st time, carl |
28th Sep, 2011 at 10:39:52pm
Thanks Carl, just the answer I was looking for :) ultimately I want a box that, while still down to the skill to drive it, is as forgiving and slick as possible.
28th Sep, 2011 at 10:53:29pm
Yep thanks guys I think as you say a marketing ploy by jkd makes sense. So just any opinions would be a help as to longevity and driveability of both. Any of you guys driven both jk and face type boxes.? A dog box whether JKD, Swiftune, MED or Minispares, are all face dog engagement and work on the same principle, they just look different. What other type of dog engagement is there? jkd bog boxes ar enot face dogs Colin, the dogs are in the same place as a syncro box , just bigger and slightly less of them,[there appears to be no detent springs in the seelecter hubs] so there is obviously an underscut on both parties. if you miss a gear in the Don you are in bother as its a painfull experience trying to select a cog once the corresponding two sets of dogs have a significantly missmatched speed, anmd a sthere are lots of them its dificult to slot in place ERGO RULE NO 1, learn to change gear 1st time, carl Ah, that's something I never knew, if it wasn't already obvious
28th Sep, 2011 at 10:56:17pm
until this cam up tonight I always thought that involute refered to a reverse angle on the dog to hold it in gear On 28th Aug, 2011 Kean said:
28th Sep, 2011 at 11:01:24pm
until this cam up tonight I always thought that involute refered to a reverse angle on the dog to hold it in gear so did i ,lol. but then i make wheels not gears, |
28th Sep, 2011 at 11:04:02pm
until this cam up tonight I always thought that involute refered to a reverse angle on the dog to hold it in gear so did i ,lol. but then i make wheels not gears, I've been searching for a hobber, so there's time yet
