| Home > Help Needed / General Tech Chat > Brief Misfire after heavy braking - what causes it? | |||||||
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
30th Sep, 2011 at 09:41:24pm
Guys, I've had this problem for AGES, now over two different engines.
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
30th Sep, 2011 at 09:47:02pm
Fuel slopping away from the pump? On 11th Feb, 2015 robert said:
30th Sep, 2011 at 09:49:37pm
1. Has it been properly set up on a dyno?
30th Sep, 2011 at 09:55:25pm
Alloy tank in the boot is sumped, Currently got a Facet solid state (180bhp claimed capacity) pump, although previously had a redtop and same issue. 8mm fuel lines all the way.
Edited by Prawn on 30th Sep, 2011. Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
30th Sep, 2011 at 09:57:42pm
float to high? On 28th Aug, 2011 Kean said:
1st Oct, 2011 at 08:16:53am
Have you got or can you borrow a sideband, check if it goes lean or rich when you get this misfire?
1st Oct, 2011 at 08:17:28am
Bah stupid phone, Wideband obviously.
![]() 99 Posts Member #: 9550 Advanced Member Cornwall, UK. |
2nd Oct, 2011 at 01:04:43pm
Gotta be something like float level incorrect..? G-force of braking causing fuel to slosh forward in carb.? Fits symptoms perfectly and only the carb remains the same across all builds.? Setup on dyno okay as vehicle static.? For every action there is an equal and opposite criticism. |
2nd Oct, 2011 at 01:18:36pm
My black Metro used to do that, always getting a flame or two out of the tailpipe. Always put it down to timing. On 19th Jan, 2010 wil_h said:
2nd Oct, 2011 at 07:38:27pm
I,m guessing that the fuel is loading up in the manifold and then causing an over-rich misfire until it clears. As said, a wideband will give you the answer. |
