Home > Help Needed / General Tech Chat > Standard fuel tank with turreted damper mounts
longy
Member #: 2727
Bicester
Just wondering is it possible to use a standard fuel tank with turreted rear damper mounts
Chris
1972 998 TURBO SLEEPER
longy
Member #: 2727
Bicester
Kindly Nic has just answered my question, yes you can use a standard tank with turrets, but the tank needs to modifed with a big hammer *Clapping* *Clapping* *Clapping* *Clapping*
I am going to start this in the next weeks and was thinking of doing a How to on it mate.
I have seen the info in the mini mag as a starting point.
simon.
longy
Member #: 2727
Bicester
Hey mate i know which article you mean, this is the build thread for the car the article was based on. hope it could be of some help
http://www.turbosport.co.uk/showthread.php...31-Mini-Project
Are you getting your mate locally to make up some turrets?
I cant see it mate, yes i was going to make some up and see what its all about.
simon.
longy
Member #: 2727
Bicester
What diameter tube are you planning on using? 4" seems popular, but ive found some 3 1/4" OD tube, would result in less modification to the tank.
I was looking for some 4'' but then i was thinking of just making it up on the roller i am not to sure.
Kad have told me to do it and spin the shock absorbers round, so that the offset at the top is the other way round, which will give me a better shocker angle and gives you clearance around everything.
so i will have to see.
Will be a shame to choppy choppy your shell
Edited by gr4h4m on 6th Oct, 2011.
longy
Member #: 2727
Bicester
I agree graham, ive got the coilovers fitted on my car at the moment and they just clear the arch, so im tempted to not to turret them.
topcat
Member #: 9408
Tiptree, Essex
What makes it better? The arc of standard radius arms is at 90° to the offset that would give, with McPhearson struts or double wishbones I can see the thinking, but with radius arms..?
www.topcatcustom.co.uk
wez
Member #: 9271
Stoke on Trent
it does make sense, the damper will lean over at the top slightly, and if you had any sort of negative camber it would then put the top and bottom mount on a similar axis/plain of movement. thats how i understand it anyway.
one day boost will be mine!
