Home > General Chat > Sealing garage floor
Get keys to new house tomorrow, looking at sealing the garage floors with 50/50 mix pva then two part garage floor paint painted over the top, was also thinking about 50/50 mix pva on the walls.
Any thoughts? really just want to keep concrete dust to a minimum while i have the chance.
wez
Member #: 9271
Stoke on Trent
At the risk of sounding like a muppet, is floor paint alone not enough?
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
Ben H
Member #: 184
Melton Mowbray, Pie Country
I did PVA my floor and then used Leyland floor paint from screwfix. Worked fine. For the walls I just used the cheapest white paint I could find. Mind you the concrete blocks just sucked up the paint. Well worth it though.
http://www.twin-turbo.co.uk
tadge44
Member #: 2500
Buckinghamshire
I applaud the PVA plus paint, but cheap emulsion paint on the walls is enough, and white helps with keeping the light levels up.
dig-mini
Member #: 9269
Rotherham
You don't need to pva the floor unless it says on the tin
Craig
Craig
I mixed mine 5:1.
I found the easiest/quickest way was to just mix it in a bucket then just pour it over the floor and used a broom to spread it out. Took about half an hour to do the whole floor so well worth doing. *oh well*
wng691s clubby
Member #: 9252
Cleethorpes
i work at a chemical plant that produces different forms of laytex and we use one of them to mix with paint for this very reason best to use the cheapest paint you can and do a 50/50 mix lasts for years one guy painted the out side of his house about ten year ago and he says it still looks like new. i can get you some if you would like
Done now needs redoing lol
i used an oil based floor paint off ebay ,30 quid for 20 litres ,did a first coat 50/50 with white spirit,then one more with just paint .looks good , i'll find out how well it lasts !at least i have half of it left over .
G13B
Member #: 1376
i´m doing mine with epoxi, started out with lyserol dust binder at first but that was shit, will be nice to have a nice clean surface:)
Im planning on doing mine with those rubber floor tiles neil, as in grahams pic i commented on? The plan is to keep the floor a bit warmer.lol
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=444565
I can't comment on the floor (I never did mine) but I would highly recommend cheap white emulsion paint for the walls (as others have suggested) rather than PVA. Emulsion paint is PVA based anyway but having all the walls white really does improve working conditions under artificial light.
pickmeup
Member #: 1200
i used pva to seal the concrete floor first then anti-slip paint from screwfix, im going to have to re-paint it soon as a lot of it has come up , but thats after 2 years of abuse
Bit of feedback
I PVA'd the double garage and then painted the floor with oil based paint 2 coats took 5ltrs with a little spare and looks good
I did not pva the single garage, took 5 ltrs of oil based paint (same as double) and was harder work to apply
Pva all the way imo
Wile E. Coyote
Member #: 7893
Portsmouth
For the Price of what PVA Costs, i Used it on mine ! I would go with it IMO too....
Jamie.
hay i went in a mate unit the other day and he put down second hand carpet tiles from an office or some where. they were cheaper then floor paint he said, and it make the place feel warm and nice to work on, it you have a spill you just lift up a tile! I likes it.
i had carpet tiles in my last garage there ok however they do lift on there own and also can soak up damp.
Wile E. Coyote
Member #: 7893
Portsmouth
On 12th Dec, 2011 wolfie said:
can soak up damp.
I had the same things with office tiles in my workshop, but got shot of them for the exact reason above.
Jamie.
Carpet also sets on fire when your welding is as bad as mine
I got a load of them from work when the gym was getting done up, it was well nice to work in there and it made the whole place warmer also i just moped it out every week.
Well worth the cash if i had to buy them.*happy*
I want some tiles for my new place
