Home > Help Needed / General Tech Chat > maestro plenum - too big?
icklebits
Member #: 228
im planning on using a maestro plenum chamber when iput the intercooler in, but the outlet on it is massive compared to the metro one and also compared to the 2" pipe im going to be using, sure i can use a reducer to take the size down but is it going to cause any problems? im thinking along the lines of lag?
ryan
minit
Member #: 141
I used a reducer with a monty plenum and haven't noticed any problems - I don't expect it'll increase the volume of your intercooler setup so much it'd make much odds.
pot_dan
Member #: 326
bradford, west yorks
i am gettign a monty plenum, is there any problems with the size of the plenum i know i read a little bit on here about size of the plenum relitive to the size of something else but i have forgotten i was new when i first read it and remember precous little about the thread, anymore info?
cheers, Dan
http://turbominis.co.uk/car/105/
The Montego, Maestro and Metro plenums are all the same aren't they ? They all use the same carb.
Phil. *smiley*
I think they are meaning the adaptor that bolts onto the plenum to which the boost hose attaches?
I know Tom. lol *laughing*
I was replying to pot dans post. He was asking if the actual plenum chamber was to big.
Phil. *smiley*
Ar right I'll shut tf up then....!
Good boy tom! lol! *happy*
'bout time! LOL!
shirt - fronts.........
pot_dan
Member #: 326
so i can just use the pipe that copmes out from the montego (to the intercooler) and use my metro plenum as its the same as the metro one anyway? just u have had my metro plenum modded now butt he RS intercooler i am gettinv at the same time has the take off for the d/v anyway, will make up my mind when i get the lot i supose lol i have the choice between escort phase 1 or phase 2 intercoolers to use will see wich one fits were best to decide unless someone knows somthing i dont?
cheers!! Dan
You can use the intercooler connection on your Metro plenum yes. Escort series 2 is supposed to be the better intercooler, the black one with the plastic end tanks.
Phil. *smiley*
pot_dan
Member #: 326
will get it all then and see whta i want to use and what i want to sell on:) cheers
Dan
