Home > Help Needed / General Tech Chat > Is this a linered block
Well i know this is a school boy question but i have never seen a linered block in the flesh before.
Its a 1275cc block so can it go out to 1380cc ??
thanks simon.
Yup, linered
and I'm pretty sure that it can't go 1380.
hazpalmer
Member #: 9038
Carlisle, Cumbria
i think without the liners it'll be around 1380 but you can put different liners in to make 1293, 1310, 1330 etc
You can line bore the liners, but only by so much.
You could probably have them pressed out, the block bored larger for new bigger liners.
I would take it to a machine shop and ask for their opinion on what is safe to do to it.
wez
Member #: 9271
Stoke on Trent
pm'd mate. :(
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
Some blocks were re-linered at the factory from what I heard. I got one years ago. It's actually still in my ever rusting mini.
I doubt they'd safely take much more than a 20thou overbore, and certainly no offset boring to achieve 1380
Im going to be taking my liners out to +30 hopefully but i reckon thats about the limit.
dfmini
Member #: 9636
my 1275 linered block has been line bored to +20.
And it's running ok since few years (n/a engine)
colas
Member #: 102
Pennsylvania USA
My linered block is also +20 and all is fine.
No good when you have 73.5mm pistons though.
If I remember correctly, boring it out to 73,5 completely removes the liner.
Bor it .020 and you'll have the strongest cylinders walls in the country *wink* Those liners are much better than cast iron.
I have heard the wear characteristics of linered blocks is far superior to that of the non linered items.
TBH Simon. If it's no good to you I'll swap you the block I have at 73mm.
