| Home > General Chat > Something Else I've Broken Which Nobody Else Has | |||||||
14th Apr, 2005 at 08:31:52am
I've been running 12G940s on 998 blocks for years, but I've never had this happen before. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
14th Apr, 2005 at 11:15:53am
brass bung it...
AlexF |
14th Apr, 2005 at 12:40:30pm
bad luck mate, Team www.sheepspeed.com Racing
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
14th Apr, 2005 at 01:08:41pm
must just be particles in the water, if its done that to cast iron i'd wouldn't want to put a softer grade of material into plug it
14th Apr, 2005 at 01:35:33pm
chemical metal?
14th Apr, 2005 at 02:38:35pm
yeah a bit of jb weld, it'll be alright...lol
14th Apr, 2005 at 02:40:51pm
"Stronger than metal"
14th Apr, 2005 at 02:45:49pm
Isn't lead a 'metal'?
14th Apr, 2005 at 02:54:15pm
Yeah but would you repair a block with lead? Thought not.....!!!!!!!!!!!
14th Apr, 2005 at 03:51:03pm
I've reapired a block with a type of liquid metal :o
AlexF |
14th Apr, 2005 at 03:55:52pm
my plan is to tap the hole and plug it up and then use JB Weld to fill the hole. This will be a tempory solutiuion while I sort a new block.
14th Apr, 2005 at 04:09:38pm
the water must have sat in the space in the head gasket leaving it to eat into the block.
15th Apr, 2005 at 06:17:14am
I don't use antifreeze, no. Ihave been using water wetter of similar for a few years now..
15th Apr, 2005 at 08:27:40am
In Norway we HAVE TO use proper anti freeze, so this never happens. On several UK used engines I've rebuilt, water ways are way bigger than they are supposed to becasue of internal corrosion. I've skimemd brand new 940 heads 1mm and hit water.
15th Apr, 2005 at 04:18:48pm
In all my road cars I use anti-freeze, but the hillclimber never sees freezing conditions and the water wetter keeps it cooler. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
17th Apr, 2005 at 01:28:59am
wil_h, know it prob doesnt apply to you as youv no doubt opened the chambers of your 12G940. but i found that SOME 12g940's had chambers that sat just inside the fire ring, and allowed the use of normal tear-drop-cylinder shaped 998 gaskets to be used. i took an old gasket along to scrappy's / mini specialists when picking out a suitable head :) turbo 16v k-series 11.9@118.9 :)
17th Apr, 2005 at 01:31:30am
should add when i pocketed my block i was carefull to stay inside the gasket line of a normal 998 gasket too, so that option was open to me :) turbo 16v k-series 11.9@118.9 :)
17th Apr, 2005 at 08:38:51pm
Yeah, I checked a 998 gasket, it's fine on the block (fits around the pockets etc.) but the head chyambers, as you say, are outside the fire ring of the 998.
